Visor issue, Sagging and falling out... |
Chucktone |
Jul 13 2020, 03:14 PM
Newbie Group: Members Posts: 4 Joined: 12-July 17 From: Austin Member No.: 21,251 Region Association: Southwest Region |
Hi All,
The visors on my '76 914 will not stay in place. It's as though the parts you insert into the mounting brackets are a bit too short. Any advice is welcome. |
BPic |
Jul 13 2020, 03:26 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
Does it flop or slide out of the pins?
There is a screw at each end that tighten a clip on the inside that clamps around the post that they are inserted on. You can adjust the side to side by loosening both get the correct left to right centered and tighten this screw. |
76-914 |
Jul 13 2020, 03:56 PM
Yep, the pins have slid inside the visor too far. Loosen those screws and pull the out until they are firmly nested. Then tighten to the desire tension. (IMG:style_emoticons/default/beerchug.gif)
mmichalik |
Jul 13 2020, 04:40 PM
MikeM Group: Members Posts: 697 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I was having the same issue on my '74. It was pretty old and tired looking so I bought a new set of hardware for the visors from 914Rubber.
When I went to pull the old hardware out, the piece inside the passenger side visor was actually a pencil that someone whiddled down to fit. I should have taken a pic of it and posted in the DAPO thread that was floating around a couple of months ago. |
Mikey914 |
Jul 13 2020, 06:47 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
One of the reasons we made the visor clips was to give a solid mount. The loose plastic pins require you to tighten down to hold in place. As you rotate them the clamp bites sinto the plastic requires more pressure to rotate. We use stainless pins so as the clip turns around it the stainless allows it to spin. The OEM were steel plated with chrome. So as it spun the chrome is worn, so if it gets wet you get rust.
Coondog |
Jul 13 2020, 06:55 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Replaced my old stock pins with the 914 rubber pins and my loose visor problems went away.
Chucktone |
Jul 16 2020, 12:20 PM
Thanks for help. All things considered, an easy fix.
dr914@autoatlanta.com |
Jul 16 2020, 12:27 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you must seat the pins into the plastic clip and make sure that they are firmly in there. Then stick the assembly into the visor with the screw very loose and mount the visor. THEN slowly tighten the tensioning screw until the visor just holds itself up
Hi All, The visors on my '76 914 will not stay in place. It's as though the parts you insert into the mounting brackets are a bit too short. Any advice is welcome. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:58 PM |
