WTB window channel fuzzies |
914andy |
Jul 13 2020, 05:05 PM
Member Group: Members Posts: 59 Joined: 23-December 11 From: Nashville tn Member No.: 13,929 Region Association: None |
Hello all,
I looking for left and right fuzzies that go in the door window channels. I have a 71 six and apparently the early 914's are different from later ones. I reckon these are NLA. I would like to find a couple in decent shape if possible...not concours but not falling apart when you pick them up. Or...if someone is making these point me to them. I haven't found them yet. many thanks Andy |
theer |
Jul 13 2020, 08:07 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Andy,
914Rubber makes them new. Tom |
euro911 |
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Check out 914rubber.com (IMG:style_emoticons/default/type.gif)
Inner fuzzies: https://900designs-container.zoeysite.com/i...sealing-strip-1 Outer fuzzies: https://900designs-container.zoeysite.com/o...sealing-strip-1 |
914andy |
Jul 13 2020, 09:29 PM
I will be contacting them anyway but I don't believe thats what I need. I am looking for the piece that goes inside the vertical window channel that the front of the up/down side window goes in. The fixed vent window goes on the other Side of the channel.
The gap on late 914's is 6mm....gap on the early 914s is 3mm. upward and onward Andy |
euro911 |
Jul 14 2020, 12:29 AM
Might have to look at early 911/912 - or possibly VW parts? I purchased window channel fuzzy inserts for my '66 912, but don't remember exactly where - it's been several years. I'll see iffin I can find the invoice (IMG:style_emoticons/default/popcorn[1].gif)
rhodyguy |
Jul 14 2020, 07:15 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Those Fuzzy links are the items on the inner and outer top of the doors. Are you referring to the front and rear verticle channels the the windows run up and down in? Does your car have early or late window regulators?
bdstone914 |
Jul 14 2020, 08:43 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@914andy
' date='Jul 13 2020, 08:29 PM' post='2833591'] I will be contacting them anyway but I don't believe thats what I need. I am looking for the piece that goes inside the vertical window channel that the front of the up/down side window goes in. The fixed vent window goes on the other Side of the channel. The gap on late 914's is 6mm....gap on the early 914s is 3mm. upward and onward Andy [/quote] Early cars with original regulators do not have fuzzys in the vertical channel. They have four rollers that guide the window in the channel. If you convert to scissor type regulators you can add the fuzzys. |
rhodyguy |
Jul 14 2020, 09:12 AM
And swap the F&R vert Channels and rear window caps.
bdstone914 |
Jul 14 2020, 09:39 AM
@rhodyguy
date='Jul 14 2020, 08:12 AM' post='2833692'] And swap the F&R vert Channels and rear window caps. [/quote] It is not needed to swap the vertical front and rear channels when converting to late regulators. I just tore down a set of early 914 doors that have no reinforcements, use early front vertical posts with fuzzies. You may be correct on the rear guide cap for the glass. I am going to check those doors to see what was used. @914andy |
914andy |
Jul 14 2020, 09:40 AM
Alright then...even at a ripe old age I still learn something new everyday! (IMG:style_emoticons/default/idea.gif)
And just because I seem to be good friends with Murphy, I would imagine swapping some of this over to later model stuff is easier said than done. I will find out one day...but not today. Thanks for all the info Andy |
rhodyguy |
Jul 14 2020, 10:08 AM
1970-72 Channel, Glass Guide Front 914 542 013 10 L and 014 10 R
1973-76 Channel, Glass Guide front 914 542 013 11 L and 041 11 R The rear is listed as common for both. |
euro911 |
Jul 14 2020, 11:40 AM
cary |
Jul 14 2020, 10:21 PM
euro911 |
Jul 15 2020, 07:25 PM
Unfortunately it states those are for 1973-1976 doors (IMG:style_emoticons/default/dry.gif)
Mikey914 |
Jul 15 2020, 10:10 PM
The rubber man Group: Members Posts: 12,656 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The metal is the same on all.
You can't use any fuzzy on the front as the early uses rollers in the track. Do you still have the plastic fin on the back of the glass? |
914andy |
Jul 16 2020, 08:43 AM
I think some of our definitions need to be clarified.
What do you mean all the metal is the same? The front metal long channel that bolts close to the bottom inside the door that the window goes up and down in. I have a 74-4 and a 71-6....they are definitely different. Once I have the time to investigate further...maybe I will learn what the rollers are. Just seems kinda odd that there is nothing in that channel but some rollers. Maybe thats why doors rust so easily....seems like a lot of water could get in there. And I reckon I don't know what the plastic fin is. Is it the cap for the vent window that screws the channel at the front top? Since I just took possession of the car after a loooooong wait, I'm in no hurry to start tearing things apart. Thats what winter is for. Andy |
Lo-Fi Version | Time is now: 6th May 2024 - 07:22 AM |
