Speedometer and angle drive |
mtndawg |
Jul 13 2020, 09:01 PM
Member Group: Members Posts: 413 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I’ve got a new speedo cable and could get 150 mph with a drill which means everything works with the cable and dash gauge. What’s the problem with the angle drive? How do I troubleshoot this?
Attached thumbnail(s) |
ndfrigi |
Jul 13 2020, 09:27 PM
is your speedo gauge not goin up? maybe you got the wrong angle drive.
Try using a drill with screw driver tip to turn the cable, clockwise and counter clockwise and see if your speedo gauge will work on which turn. I had issue before and ended up my angle drive is not the right one for 914. My speedo arm move when I turn my speedo cable like doing a reverse. |
mtndawg |
Jul 13 2020, 11:38 PM
How do I know if it’s the right one? I’m spinning the cable counter clockwise to get the speedometer to run.
ndfrigi |
Jul 14 2020, 12:37 AM
How do I know if it’s the right one? I’m spinning the cable counter clockwise to get the speedometer to run. If car can be driven, try to do a reverse drive and use celphone to record the speedo gauge if it is going up (I said use celphone so you will not get into accident doing a reverse but looking at your gauge, unless you have a good clear on your road). If angle drive is remove from transmission, turn one side of the angle drive and see if the other end turns the opposite way. My speedo on my 1st 914 has non working speedo gauge until I compare my extra angle drive to the one in the car, one angle drive turns both end on same direction and one angle drive turns the opposite way. Just can’t remember now which one is the correct angle drive since I fixed mine last 2012. If I have time tomorrow, I can take a video of that angle drive since I still have it and I have both kind of angle drive on my boxes of parts. |
76-914 |
Jul 14 2020, 07:33 AM
Chunk it and buy a rebuilt one from bruce. IIRC, he sells them cheaply. @bdstone914
bdstone914 |
Jul 14 2020, 08:32 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have them but they are not rebuilt. They all wear. |
bdstone914 |
Jul 14 2020, 08:36 AM
@mtndawg
' date='Jul 13 2020, 08:01 PM' post='2833586'] I’ve got a new speedo cable and could get 150 mph with a drill which means everything works with the cable and dash gauge. What’s the problem with the angle drive? How do I troubleshoot this? [/quote] Remove the cable at the speedo drive. Try to turn the tab on the drive. If it turns it is shot. |
JeffBowlsby |
Jul 14 2020, 08:49 AM
914 Wiring Harnesses Group: Members Posts: 8,479 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
What does this thread have to do with reverse lights?
mtndawg |
Jul 14 2020, 09:34 AM
mtndawg |
Jul 14 2020, 11:21 AM
Unbelievable, I just pulled the car backwards down my street and the speedometer works! So I must have a 911 part. @bdstone914
ndfrigi |
Jul 14 2020, 11:49 AM
Unbelievable, I just pulled the car backwards down my street and the speedometer works! So I must have a 911 part. @bdstone914 problem solved! now just need the correct angle drive. |
mtndawg |
Jul 14 2020, 12:55 PM
Does this mean I can loosen the large nut and only replace the 90 degree angle part? I don't have to remove the entire assembly released by the set screw? Appreciate the advice here to solve the problem.
DRPHIL914 |
Dr. Phil Group: Members Posts: 5,759 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Unbelievable, I just pulled the car backwards down my street and the speedometer works! So I must have a 911 part. @bdstone914 problem solved! now just need the correct angle drive. just saw this but had the same issue posted on my thread the same issue, i got a new speedo angle drive from Pelican and it was the 911 one, so goes opposite and will not work for 914! best price ive found for a 914 part# VDO oem part #91431802901 was $138 at FCP Euro . Pelican was $168 and Porsche was $200. Dr. Phil. |
ndfrigi |
Jul 14 2020, 01:10 PM
bdstone914 |
Jul 14 2020, 07:45 PM
@mtndawg
' date='Jul 14 2020, 11:55 AM' post='2833758'] Does this mean I can loosen the large nut and only replace the 90 degree angle part? I don't have to remove the entire assembly released by the set screw? Appreciate the advice here to solve the problem. [/quote] Yes loosen the big nut and remove the angle drive only. not not remove the 13mm hex head bolt that holds in the angle drive bushing. You probably have a 911 speedo drive. Look at the part number on the end cap. It will start 911 Bruce |
mtndawg |
Jul 14 2020, 10:57 PM
@bdstone914 sent you a pm...
Steve |
Jul 15 2020, 08:27 AM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
A lot of money for that angle drive.
How much more is a GPS speedometer versus bouncy 914 speedo? |
76-914 |
Jul 15 2020, 11:53 AM
About $100 before tax, Steve. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 26th April 2024 - 11:29 AM |
