Speedometer and angle drive |
mtndawg |
Jul 13 2020, 09:01 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I’ve got a new speedo cable and could get 150 mph with a drill which means everything works with the cable and dash gauge. What’s the problem with the angle drive? How do I troubleshoot this?
Attached thumbnail(s) |
mtndawg |
Jul 14 2020, 12:55 PM
Does this mean I can loosen the large nut and only replace the 90 degree angle part? I don't have to remove the entire assembly released by the set screw? Appreciate the advice here to solve the problem.
bdstone914 |
Jul 14 2020, 07:45 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@mtndawg
' date='Jul 14 2020, 11:55 AM' post='2833758'] Does this mean I can loosen the large nut and only replace the 90 degree angle part? I don't have to remove the entire assembly released by the set screw? Appreciate the advice here to solve the problem. [/quote] Yes loosen the big nut and remove the angle drive only. not not remove the 13mm hex head bolt that holds in the angle drive bushing. You probably have a 911 speedo drive. Look at the part number on the end cap. It will start 911 Bruce |
Lo-Fi Version | Time is now: 29th May 2024 - 06:20 AM |
