Once every 15 starts of so starter grinds like the engine is already started |
zfisher6164 |
Jul 17 2020, 09:27 AM
Newbie Group: Members Posts: 41 Joined: 19-January 19 From: California Member No.: 22,809 Region Association: None |
brant |
Jan 28 2021, 07:45 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Your flywheel ring gear is most likely toast now.
You will have to pull the trans to change the flywheel or at least ring gear Don’t forget to set the crank shaft end play when you change out the flywheel |
Lo-Fi Version | Time is now: 27th May 2024 - 02:46 AM |
