Once every 15 starts of so starter grinds like the engine is already started |
zfisher6164 |
Jul 17 2020, 09:27 AM
Newbie Group: Members Posts: 41 Joined: 19-January 19 From: California Member No.: 22,809 Region Association: None |
aexe |
Feb 5 2021, 02:47 PM
Newbie Group: Members Posts: 10 Joined: 28-December 18 From: San Francisco Member No.: 22,756 Region Association: Northern California |
Here's the starter gear... The flywheel looked ok from what I could see. I read somewhere, and the logic seemed sound to me, that you could put the car in 5th and turn the raised rear wheels and the flywheel would rotate. However, in my case, just the opposite wheel would turn. Does this opposite wheel need to be fixed in order for the flywheel to turn? Just now thinking about this.
Attached thumbnail(s) |
wndsrfr |
Mar 3 2021, 01:26 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Here's the starter gear... The flywheel looked ok from what I could see. I read somewhere, and the logic seemed sound to me, that you could put the car in 5th and turn the raised rear wheels and the flywheel would rotate. However, in my case, just the opposite wheel would turn. Does this opposite wheel need to be fixed in order for the flywheel to turn? Just now thinking about this. Something is wrong with this. There should not be any mark on the pinion gear nose. There is an alignment issue here in which the nose of the pinion gear is too close to the flywheel. Look carefully at the mounting surface...and get another Bosch starter. Paint the nose of the pinion gear, install & do several starts then inspect.... |
brant |
Mar 3 2021, 02:24 PM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Here's the starter gear... The flywheel looked ok from what I could see. I read somewhere, and the logic seemed sound to me, that you could put the car in 5th and turn the raised rear wheels and the flywheel would rotate. However, in my case, just the opposite wheel would turn. Does this opposite wheel need to be fixed in order for the flywheel to turn? Just now thinking about this. Something is wrong with this. There should not be any mark on the pinion gear nose. There is an alignment issue here in which the nose of the pinion gear is too close to the flywheel. Look carefully at the mounting surface...and get another Bosch starter. Paint the nose of the pinion gear, install & do several starts then inspect.... I'm going to guess this is the replica high torque starter from ebay for 100 they require a shim to get the depth correct and over extend into the flywheel without the shim |
Lo-Fi Version | Time is now: 27th May 2024 - 05:13 AM |
