FS various bits 1 of 3, misc parts |
dangrouche |
Jul 17 2020, 01:43 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
UPDATE July 20, 2020. Thanks all for buying up these parts from this posting. It's been a while since I listed stuff for sale and did not realize that worn CVs do not have a market, and therefore I am removing them and the pics from this listing.
Prices do not include shipping. I ship by the Postal Service from California zip 94005 (suburb outside of San Francisco) and accept PayPal. NO international shipping. Private mail (PM) what you want and provide me your zip code, then I will pack it into smallest box possible and weigh the purchase and use the postal website to figure the cheapest way possible with tracking. I will PM the amount owed (items + postage owed). PayPal me as a friend and I’ll ship it out and provide you tracking after I’ve shipped from the post office. lthough the stuff is listed pretty cheaply, postage may exceed cost of the item, so buy up a load of stuff (marketing here ) and I’ll put it in a USPS flat rate box or parcel post it. Your post of what you want is a “soft commitment” so the rest of the board that the item is spoken for and I will “line out” on the post that the item is sold. C Oil filter mount $8 D G relay board stud $2 B1 glove box lid $5 B2 bumper dog bone $1 B3 passenger headlight motor cover $3 B4 square to round transition for blower motor $3 B5 passenger wiper arm $3 B6 driver door lid spring $1 CV joint #3 CV joint #4 D2 drain (does not have crack on either ear) with tube $2 D4 rear brake shield mount (pair) $2 D5 accelerator pedal cover coated coated with POR15 $3 D6 accelerator pedal board washer coated with POR15 $2 Driver A housing $8 Driver B housing $8 Passenger A tail light housing $8 Passenger B tail light housing $8 E1 fuel sender(has been disassembled and determined to be fully operational) $20 E2 front signal housing bracket $1 E3 bicycle derailleur cables for thermostat (two available) $1 each G1 tray $2 G2 tray $2 J1 battery ground cable $2 J3 set of five VW hubcaps J4 early gas cap (NEEDS total rebuild/rebuild of soft rubber parts on the underside) $2 K1 fabricated oil cooler relocation kit K2 defroster knob $2 K4 fabricated glove box shelf white $3 O USED pair of tie rod ends $8 P surface rusted master cylinder reservoir strap $3 R driver quality Hella lens (has fracture crack) $3 T MPS untested $4 V MPS untested $4 |
Retroracer |
Jul 17 2020, 05:47 PM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
I'll take the gauges LOT and the E1 fuel sender please. Will PM you,
- Tony |
ndfrigi |
Jul 17 2020, 06:35 PM
I will take the following:
B Oil filler with bail $3 B8 accelerator pedal rod assembly $4 I may add more from your list but waiting for some pictures of other items. thank you! |
dangrouche |
Jul 17 2020, 06:55 PM
dangrouche |
Jul 17 2020, 06:56 PM
I will take the following: B Oil filler with bail $3 B8 accelerator pedal rod assembly $4 I may add more from your list but waiting for some pictures of other items. thank you! I had to post two subsequent separate messages since pics were too large for a single listing. The oil filler+bail and pedal rod are yours. |
ndfrigi |
Jul 17 2020, 07:04 PM
I will take the following: B Oil filler with bail $3 B8 accelerator pedal rod assembly $4 I may add more from your list but waiting for some pictures of other items. thank you! I had to post two subsequent separate messages since pics were too large for a single listing. The oil filler+bail and pedal rod are yours. email all your pictures to yourself and it will ask you what size and just select medium. than go to your email inbox and save them to your computer or cellphone and use those newly saved pics. You can add more pics per post. Or just reply to your post and add more pictures. |
Olympic 914 |
Jul 18 2020, 02:35 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I will take
N - 2.0 Throttle body $5 U - 280100043 MPS $4 L1/L2 - Valve covers $20 |
dangrouche |
Jul 18 2020, 06:49 PM
dangrouche |
Jul 18 2020, 06:50 PM
frostyf |
Jul 19 2020, 02:48 PM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Hi if they've not gone can I take :
J - ECU Clamp (if it fits 2.0l ECU); F1 - rubber rings pliable and untorn; Q - engine compt light? Could you let me know if these are available or if they've already gone. Thank you, Nick J ECU bracket, with DEFECT F1 set of three rubber rings for console gauges (all perfect and pliable and untorn) $8 Q engine compartment light housing (not cracked) $3 |
Gearup |
Jul 19 2020, 05:12 PM
Member Group: Members Posts: 154 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Passenger Tailight housing. How is the condition if available?
Thanks |
dangrouche |
Jul 19 2020, 09:35 PM
Hi if they've not gone can I take : J - ECU Clamp (if it fits 2.0l ECU); F1 - rubber rings pliable and untorn; Q - engine compt light? Could you let me know if these are available or if they've already gone. Thank you, Nick J ECU bracket, with DEFECT F1 set of three rubber rings for console gauges (all perfect and pliable and untorn) $8 Q engine compartment light housing (not cracked) $3 they are yours ! |
dangrouche |
Jul 19 2020, 10:11 PM
Passenger Tailight housing. How is the condition if available? Thanks The "best passenger housing" has defects in the channel in that they are not continuous. There is corrosion on the bulb contacts, so each housing will need attention. On a scale of 1-5, I'd rate these housings at best a "1.5" and barely reaching a "2." I'm considering removing all of the housings out of the listing because most buyers would be disappointed because all all of the housings has defects in that sections of the channel where the lenses beds with the rubber seal. Putting myself in your shoes and paying $15 (Postal medium box for postage) and $8 for a total of $23. I'm conflicted to even sell these to forum members. A pair of housings for $31 are good for a person who doesn't have anything at all. These housings are best used for their reflectors. If I laid this out a at a swap meet we'd meet in the middle and I'd let it go for $5. |
hcdmueller |
Jul 20 2020, 01:28 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I'll take the following.
A Alternator tin with alternator with plastic trim washer $6 D dizzy clamp with nut and washer $3 K Sump cover with used “O” ring $2 Thanks, Chris |
dangrouche |
Jul 20 2020, 09:46 PM
frostyf |
Jul 21 2020, 07:04 AM
Ben, can I check which fan this is for (my ignorance sorry). Does this hold a blower fan in the engine bay onto the firewall??
F circulation fan clamp $2 Thanks Nick |
dangrouche |
Jul 21 2020, 10:01 AM
Lo-Fi Version | Time is now: 10th May 2024 - 10:37 PM |
