dangrouche
Jul 17 2020, 01:43 PM
UPDATE July 20, 2020. Thanks all for buying up these parts from this posting. It's been a while since I listed stuff for sale and did not realize that worn CVs do not have a market, and therefore I am removing them and the pics from this listing.
Prices do not include shipping. I ship by the Postal Service from California zip 94005 (suburb outside of San Francisco) and accept PayPal. NO international shipping. Private mail (PM) what you want and provide me your zip code, then I will pack it into smallest box possible and weigh the purchase and use the postal website to figure the cheapest way possible with tracking. I will PM the amount owed (items + postage owed). PayPal me as a friend and I’ll ship it out and provide you tracking after I’ve shipped from the post office. lthough the stuff is listed pretty cheaply, postage may exceed cost of the item, so buy up a load of stuff (marketing here ) and I’ll put it in a USPS flat rate box or parcel post it.
Your post of what you want is a “soft commitment” so the rest of the board that the item is spoken for and I will “line out” on the post that the item is sold.
A Alternator tin with alternator with plastic trim washer $6
B Oil filler with bail $3
C Oil filter mount $8
D dizzy clamp with nut and washer $3
E fan blade washer $1
F circulation fan clamp $2
G relay board stud $2
H set of four injector hold down clamps $4
I set of fuel rails, both with test ports $4
J ECU bracket, with DEFECT (one nut has sheared off bolt in it, needs to be drilled out) $3
K Sump cover with used “O” ring $2
A1 djet fuel pressure regulator from 2.0 liter $5
A2 thermotime switch $4
A3 cold start valve for 2.0 djet $4
A4 sensor for 2.0 djet $3
B1 glove box lid $5
B2 bumper dog bone $1
B3 passenger headlight motor cover $3
B4 square to round transition for blower motor $3
B5 passenger wiper arm $3
B6 driver door lid spring $1
B7 set of door panel captive nuts $1
B8 accelerator pedal rod assembly $4
CV joint # 1 $15 (spider cage has no defects)
CV joint # 2 [s]$15 $8 (single defect present) change spider recommended
CV joint #3 $15 $8 (single defect present) change spider recommended
CV joint #4 $15 $8 (single defect present) change spider [/s]recommended[/s]
D 1 drain (has bother ears but one ear has a crack) with tube $3
D2 drain (does not have crack on either ear) with tube $2
D3 plastic washer for alternator $2
D4 rear brake shield mount (pair) $2
D5 accelerator pedal cover coated coated with POR15 $3
D6 accelerator pedal board washer coated with POR15 $2
Driver A housing $8
Driver B housing $8
Passenger A tail light housing $8
Passenger B tail light housing $8
E1 fuel sender(has been disassembled and determined to be fully operational) $20
E2 front signal housing bracket $1
E3 bicycle derailleur cables for thermostat (two available) $1 each
E4 rear view mirror (just needs adhesive patch to mount) $25
F1 set of three rubber rings for console gauges (all perfect and pliable and untorn) $8
F2 fully functional dwell tach gauge $8
G1 tray $2
G2 tray $2
H1 relay board $5
H2 relay board $5
J1 battery ground cable $2
[s]J2 fully functional fan motor with bracket $35[/s]
J3 set of five VW hubcaps $10 $6
J4 early gas cap (NEEDS total rebuild/rebuild of soft rubber parts on the underside) $2
K1 fabricated oil cooler relocation kit $5 $3
K2 defroster knob $2
K3 fabricated glove box shelf black $3
K4 fabricated glove box shelf white $3
L1/L2 pair of valve covers $20
LOT of gauges with three rubber rings (for parts only, Speedometer is only unit with glass intact, all other gauges have been opened for the glass faces) Sold as a lot for a shipped price of $25 (LOT sale of $10 for the gauges and $15 postage)
M flow meter for 1.8 lite, for parts $5
N 2.0 throttle body for parts (pivot binds when throttle plate actuated) $5
O USED pair of tie rod ends $8
P surface rusted master cylinder reservoir strap $3
Q engine compartment light housing (not cracked) $3
R driver quality Hella lens (has fracture crack) $3
S driver quality side marker Hella lens with screws (has fracture crack) $3
T MPS untested $4
U MPS untested $4
V MPS untested $4
W 1.8 vacuum advance (#981) $5
Y vacuum advance tested (#889) $5[s] [/s]
Retroracer
Jul 17 2020, 05:47 PM
I'll take the gauges LOT and the E1 fuel sender please. Will PM you,
- Tony
ndfrigi
Jul 17 2020, 06:35 PM
I will take the following:
I may add more from your list but waiting for some pictures of other items.
thank you!
dangrouche
Jul 17 2020, 06:55 PM
QUOTE(Retroracer @ Jul 17 2020, 04:47 PM)
- Tony
the LOT of gauges was already sold
dangrouche
Jul 17 2020, 06:56 PM
QUOTE(ndfrigi @ Jul 17 2020, 05:35 PM)
thank you!
I had to post two subsequent separate messages since pics were too large for a single listing. The oil filler+bail and pedal rod are yours.
ndfrigi
Jul 17 2020, 07:04 PM
QUOTE(dangrouche @ Jul 17 2020, 05:56 PM)
thank you!
email all your pictures to yourself and it will ask you what size and just select medium. than go to your email inbox and save them to your
computer or cellphone and use those newly saved pics. You can add more pics per post.
Or just reply to your post and add more pictures.
Olympic 914
Jul 18 2020, 02:35 PM
I will take
N - 2.0 Throttle body $5
U - 280100043 MPS $4
L1/L2 - Valve covers $20
dangrouche
Jul 18 2020, 06:49 PM
QUOTE(Olympic 914 @ Jul 18 2020, 01:35 PM)
I will take
they are yours, in addition to A1 (fuel press. reg) B2 (bumper dogbone)
thanks!
dangrouche
Jul 18 2020, 06:50 PM
- Tony
The Fuel sender (E1) is still available to anyone interested. Retroracer changed his mind.
frostyf
Jul 19 2020, 02:48 PM
Hi if they've not gone can I take :
J - ECU Clamp (if it fits 2.0l ECU);
F1 - rubber rings pliable and untorn;
Q - engine compt light?
Could you let me know if these are available or if they've already gone.
Thank you,
Nick
Gearup
Jul 19 2020, 05:12 PM
Passenger Tailight housing. How is the condition if available?
Thanks
dangrouche
Jul 19 2020, 09:35 PM
QUOTE(frostyf @ Jul 19 2020, 01:48 PM)
Thank you,
Nick
they are yours !
dangrouche
Jul 19 2020, 10:11 PM
QUOTE(Gearup @ Jul 19 2020, 04:12 PM)
Thanks
The "best passenger housing" has defects in the channel in that they are not continuous. There is corrosion on the bulb contacts, so each housing will need attention. On a scale of 1-5, I'd rate these housings at best a "1.5" and barely reaching a "2." I'm considering removing all of the housings out of the listing because most buyers would be disappointed because all all of the housings has defects in that sections of the channel where the lenses beds with the rubber seal. Putting myself in your shoes and paying $15 (Postal medium box for postage) and $8 for a total of $23. I'm conflicted to even sell these to forum members. A pair of housings for $31 are good for a person who doesn't have anything at all. These housings are best used for their reflectors. If I laid this out a at a swap meet we'd meet in the middle and I'd let it go for $5.
hcdmueller
Jul 20 2020, 01:28 PM
I'll take the following.
Thanks, Chris
dangrouche
Jul 20 2020, 09:46 PM
QUOTE(hcdmueller @ Jul 20 2020, 12:28 PM)
Thanks, Chris
they are yours!
frostyf
Jul 21 2020, 07:04 AM
Ben, can I check which fan this is for (my ignorance sorry). Does this hold a blower fan in the engine bay onto the firewall??
Thanks Nick
dangrouche
Jul 21 2020, 10:01 AM
QUOTE(frostyf @ Jul 21 2020, 06:04 AM)
Thanks Nick
It’s yours
