Fuel Pump Q, Whats the fix or work around |
Robarabian |
Jul 19 2020, 04:42 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
The car is a 1971 that I just purchased from the original owner. Sat for several years, father / son project. We have gone through the systems; cleaned the gas tank; blown out the fuel lines; changed the tank lines and several others that were suspect.
After going through pre-start up procedures, we connected everything up with fresh fuel. The car started pretty quickly but I noticed fuel started leaking at the pump. My inspection revealed fuel is sealed around the pump fittings, but fuel is leaking from the pump itself, in the area of the electric connector. New pumps seem to be 400 bucks for a "3 port" item. Is there a work around with a less expensive pump, ie., a single port? Thank you for the knowledge here in this community, I could not have learned all I have without reading all the wisdom. Photo of the car attached...hopefully. |
ndfrigi |
Jul 19 2020, 04:46 PM
Hello, you can just use late fuel pump and Napa sells them. Less fuel lines. 1 line from tank supply to inlet of fuel pump and 1 return line goes straight to tank return line. 3 ports has 2 return line split.
any updated picture of your car to share? that picture seems to be taken when you bought it. |
Beeliner |
Jul 19 2020, 04:55 PM
Member Group: Members Posts: 398 Joined: 2-August 14 From: Fairfield, CT Member No.: 17,725 Region Association: North East States |
Robarabian |
Jul 19 2020, 04:56 PM
Thank you for the insight. I will hit Napa online now.
I got it Thursday!! so yes, it is taken as I got it.. but here is one with my kids, aka, my pit crew tearing it down a bit yesterday... |
Rand |
Jul 19 2020, 05:02 PM
I had good luck with this one. I don't see the need to spend more than $25 on a new pump.
https://www.amazon.com/gp/product/B07B5ZZR7...=UTF8&psc=1 |
Robarabian |
Jul 19 2020, 05:05 PM
So the photo shows a pump with one inlet and one outlet... do you just add a "Y" connector for the return line and block the other off? Sorry if I sound dumb, but my other 914 is a suby and my prior cars were all carbureted. So I am trying to keep this car fuel injected since it is complete.
Hello, you can just use late fuel pump and Napa sells them. Less fuel lines. 1 line from tank supply to inlet of fuel pump and 1 return line goes straight to tank return line. 3 ports has 2 return line split. any updated picture of your car to share? that picture seems to be taken when you bought it. |
ndfrigi |
then borrow a loaner tool (fuel pressure test) from Napa or Pepboys or Oreily’s to confirm that you will get between 28 and 30 psi.
Robarabian |
Jul 19 2020, 05:35 PM
I found Jeff bowlsby’s diagram. Figured it out. I’ll order that BMW pump. Thanks to you guys!
Lo-Fi Version | Time is now: 17th May 2024 - 01:20 PM |
