Six Conversion question, CIS information |
Robarabian |
Jul 21 2020, 08:45 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
I am looking at possibly purchasing a 6 to do a conversion (one day)...
The owner of the motor pulled it out of his 911 and installed a 3.2. The motor has service records and was rebuilt at some point (full documentation) and at this time has about 70K on the rebuild. He cannot remember if it comes with the ECM to run the CIS. It was crated by his employer when he moved from east coast to west coast. He still has the 911, is being transferred again out of state and does not want to schlep the motor across the country again. My questions for those who have already converted, are those computers available? Expensive? This item comes complete clutch / flywheel to exhaust manifolds, all the CIS. Says it is turn key and already had Carrera Tensioners installed. Just cant confirm he has the engine management system. I know very little about CIS so this is why I am asking. it is a 2.7 engine. Thank you. Rob |
Jul 21 2020, 09:28 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
All the parts for 2.7 cis are very available. They didn’t use a computer. You often have to rebuild the wur and fd and that’s about $650. A 2.7 with 70k is almost due for a rebuild. That will be $5-12k if you do it yourself or $12-20k if you send it to a shop. Just the machine work on the case can easily cost $3k so there’s no way to do it on the cheap.
IronHillRestorations |
Jul 21 2020, 09:33 PM
I have not done a 2.7 conversion, but that is not a Lambda system so there's no ECM. I haven't done a CIS harness in several years, but pretty sure the only thing that requires power is fuel pump, warm up regulator, and CDI box. You should get a 3 pin CDI box, or some kind of ignition system with it.
Robarabian |
Jul 21 2020, 09:36 PM
These were the answers I needed. Thank you.
porschetub |
Jul 21 2020, 11:29 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
These were the answers I needed. Thank you. There were all sorts of mixtures with CIS FI ,some had an ignition ECU and other combinations such as KE-jet which was modernized CIS . In short yours is a basic but good system for starting,driving,economy but not really for performance,just make sure the engine has been stored well as CIS can be a setup nightmare due to fuel system moisture. 70K on a rebuild would worry me,these engines had a rather short lifespan (US smog spec ) unless upgraded to a better exhaust,larger cooling fan,headstuds, etc ,etc and the right "modern" rebuild work done....worth checking. Good luck on your very $$$$ journey but well worth it in the end...trust me on that. |
mlindner |
Jul 22 2020, 07:38 AM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Aside from the induction, can he provide leak-down numbers and some good picture. If not, that engine should be pretty cheap if you still want it. Best, Mark
Lo-Fi Version | Time is now: 20th May 2024 - 09:31 PM |
