How do you secure a late blower in the engine bay?, Believe its a strap - what does it secure to??? Is welding required? |
frostyf |
Jul 23 2020, 11:54 AM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Can anyone send me a photo of a late blower motor (single outlet with splitter top divert output into two hoses) is secured in the engine bay please.
Have a 1973 2.0litre which had no blower fitted. I've bought a used one which has a single outlet with a pipe coupling that splits into two. I'm not sure what I need to fit this and secure it into the engine space?? I believe the early ones (twin output) had a bracket but the later models had a strap? Is that correct? Do you know what the strap attaches to? Is welding required to the back of the engine space? If anyone has a photo that would be perfect. There's a strap for sale on the World at a great price, but before buying it I wanted to check. Can't seem to see how that fits on the PET diagrams; they seem to only have the bracket?? Thank you in advance! Nick |
914werke |
Jul 23 2020, 11:59 AM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
If your car is indeed a mid to late build date 73 you will have a stand that is spot welded to the drivers eng. shelf below the relay board
if it isnt there its probably an early build date (72 MY) in which the blower was mounted to the impeller housing & there was no stand Early blower motor Late Motor stand (yes I have these available FS) Late motor (not a great pic) |
Olympic 914 |
Jul 23 2020, 01:11 PM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
dr914@autoatlanta.com |
Jul 23 2020, 04:13 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
there is a cradle on the left front engine shelf under the relay board. There is a rubber pad in the cradle and a thick clamp around the blower and the cradle to secure it
Can anyone send me a photo of a late blower motor (single outlet with splitter top divert output into two hoses) is secured in the engine bay please. Have a 1973 2.0litre which had no blower fitted. I've bought a used one which has a single outlet with a pipe coupling that splits into two. I'm not sure what I need to fit this and secure it into the engine space?? I believe the early ones (twin output) had a bracket but the later models had a strap? Is that correct? Do you know what the strap attaches to? Is welding required to the back of the engine space? If anyone has a photo that would be perfect. There's a strap for sale on the World at a great price, but before buying it I wanted to check. Can't seem to see how that fits on the PET diagrams; they seem to only have the bracket?? Thank you in advance! Nick |
frostyf |
Jul 23 2020, 09:26 PM
Thanks for the advice and Olympic Blue, many thanks for the photos - Ideal. A picture paints a thousand words etc!!
Guess I need to buy a stand and get it welded in! |
Lo-Fi Version | Time is now: 17th May 2024 - 11:42 AM |
