Converting 1.8 to 2.0, need some help... |
914werke |
Jul 12 2005, 10:15 AM
"I got blisters on me fingers" Group: Members Posts: 10,138 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ok this is where I got lost. IIRC the 1.7, 1.8 rods (& crank) are the same. I have a running 1.7 (w. Djet of course) and also have a 1.8 core eng. bad Ljet. Was planning on direct swapping the 1.8 heads and P&C's off of the 1.8 onto the 1.7 and retaining the Djet? Also I have a set of OE 94 (2.0) P&C's that I could use ...... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) still with the 1.8 heads (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Comments? |
tat2dphreak |
Jul 12 2005, 10:23 AM
you can swap the 1.8 parts to a 1.7, no problem... the 1.8 and 1.7 have the same wristpin locale too you cannot JUST put the 2.0 P&Cs on a 1.7/1.8 crank.... you have to change the rods and crank too... you can you the djet with all of it... you MAY need to get the 2.0 injectors though... and 2.0 brain. |
914werke |
Jul 12 2005, 10:58 AM
So why cant you apply the 94's to the 1.7/1.8 rod crank combo?
Mueller |
Jul 12 2005, 11:22 AM
you can.....sorta, you just have to make sure the pistons for whatever combo you want match the correct rod/crank don't pay too much attention to bore size........... |
Type 4 Unleashed |
Jul 12 2005, 12:12 PM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
I'am surprised no one caught this yet. The 93mm 1.8 cyl, won't fit a 1.7 90mm case, with out the extra cost of opening up the 1.7 case, also the 1.8 head doesn't fit the 90mm cyl. There was a special spacer that centered the 90mm cyl in a 1.8, 2.0 head, but it's not cost effective. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
tat2dphreak |
Jul 12 2005, 12:31 PM
no one caught that because you don't have to open a 1.7, or any TIV case until you get to about 103mm pistons... all cases are the same. you have to open 1.7 HEADS for bigger pistons, not the case... but he's using the 1.8 heads, so that is a moot point. |
Bleyseng |
Jul 12 2005, 12:34 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
1.7/1.8 pistons have a different wrist pin offset than the 94mm-96mm 2.0L ones so thats why you can't mix them up!
All type 4 cases are the same spigot opening so 90mm-100mm fit. |
Jake Raby |
Jul 12 2005, 12:38 PM
ALL CASES HAVE THE SAME CYLINDER SPIGOT SIZE!!
The 1.7 head ONLY had a smaller register and smaller ports and sometimes even smaller pushrod tube bores. |
914werke |
Jul 12 2005, 01:33 PM
AHHHHH thank you Sensi (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 09:49 PM |
