Cleaning Aluminum, Suggestions for chemicals to use |
John |
Jul 11 2005, 02:21 PM
I would like some suggestions as to what to use to clean and "brighten" aluminum such as an engine case.
I don't want to media blast the case. I know this would clean it but would end up leaving a more rough surface finish that I would like. I would like to use some sort of cleaner/brightener. I plan on using a pressure washer or a spray type parts washer. In searching the web I have found only a few types that can be bought in small quantities (like a gallon). Thanks for your advise. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:18 AM |
