Replacing the lug bolts with studs and nuts |
Mcraneiowa |
Jul 25 2020, 01:24 PM
Member Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
An item on my list that I would like to consider replacing are the lug-bolts on my 914 with studs and Lug-nuts. I have aftermarket wheels that require fairly long bolts one of which I am missing and so far have been very hard to find. Also, when I went to tighten my wheels up the other day I realized one is slightly stripped. What does it entail to switch it out to studs with lugnuts? Studs with lugnuts seem much easier to work with than the bolts. I’d like to hear peoples pros and cons regarding this subject. Thanks
davep |
Jul 25 2020, 02:57 PM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
While it is not a bad idea I think you should first explore the availability of the nuts that you would need to use. Aftermarket wheels often use custom shaped seats and thus come with custom lug-bolts. So, make sure that whatever lug-nuts your will need are available with the correct thread for the studs, and correct seat for the wheels.
The other issue could be with the fit of the studs in the holes of the front rotors and rear hubs. |
IronHillRestorations |
Jul 25 2020, 06:25 PM
Pretty sure PMB sells screw in wheel studs. As long as you are staying 4 lug, and the lugs have the proper seats (as davep mentions), screw in studs aren't a terrible option. I'd probably locktite them though.
Nojoah |
Jul 25 2020, 08:22 PM
Member Group: Members Posts: 119 Joined: 6-May 20 From: Ontario Member No.: 24,234 Region Association: Canada |
Pretty sure PMB sells screw in wheel studs. As long as you are staying 4 lug, and the lugs have the proper seats (as davep mentions), screw in studs aren't a terrible option. I'd probably locktite them though. Definitely locktite. (IMG:style_emoticons/default/agree.gif) |
73-914 |
Jul 25 2020, 09:20 PM
Senior Member Group: Members Posts: 575 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
Best thing I ever did on my Audi A4 quattro
Literati914 |
Jul 28 2020, 01:26 PM
Senior Member Group: Members Posts: 1,463 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Pretty sure PMB sells screw in wheel studs. As long as you are staying 4 lug, and the lugs have the proper seats (as davep mentions), screw in studs aren't a terrible option. I'd probably locktite them though. I'm gonna add studs too, but I prefer press in studs.. just seems safer to me (confidence is a +). Of course they'd have to be pressed out and re-installed into replacement front rotors when the old rotors are replaced (expense is a -) . Ball seat nuts if using fuchs or any porsche wheel, and probably all replicas. . |
Costa05 |
Jul 28 2020, 02:26 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Looking to do the same thing on my car with longer studs. My car has what I think is original four lug studs but they are too short for my new 2.0 Fuchs I just bought. Current wheels are orig Rivs. Are original studs just threaded in for both front and back or pressed in? I think the fronts thread in but not sure on the back.
Rich |
jfort |
Jul 28 2020, 02:30 PM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I did it for a six. Got the longer studs and open nuts from Elephant Racing. I ordered the rears too long. Quick turn around to get the right ones. Great customer service. Didn't need a press. They pound out and pull right in when tightened. Be sure to test and re-torque a little later.
Literati914 |
Jul 28 2020, 06:39 PM
..My car has what I think is original four lug studs but they are too short for my new 2.0 Fuchs I just bought. .. Rich 2.0 Fuchs means you have a 914 w/4 lug - and I'm sure non came from the factory with studs.. lug bolts only. Now the /6 cars.. I'm not sure, but I do think they did come with studs. I did it for a six. Got the longer studs and open nuts from Elephant Racing. I ordered the rears too long. Quick turn around to get the right ones. Great customer service. Didn't need a press. They pound out and pull right in when tightened. Be sure to test and re-torque a little later. What length did you end up using? Got pics? . |
Lo-Fi Version | Time is now: 21st May 2024 - 03:04 AM |
