SOLD: 3.2 engine, all conversion parts, 5 lug, PMB and more in damaged chassis, SOLD |
tygaboy |
Jul 25 2020, 10:36 PM
914 Guru Group: Members Posts: 5,287 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
SOLD SOLD SOLD
Sadly, this well sorted 3.2 conversion was totaled in a roll over. Most importantly, no one was injured. Not a scratch. That said, if you're looking to do a 6 conversion, here's the proverbial "screaming deal" - $13.5 and you'll get the chassis plus: - 1984 3.2 that's recently had a thorough tuning and was/is running great. It still starts instantly and runs great and was cold start video'd today, 7/25. ECU, harness, all parts needed to run. - Turbo valve covers - Dr. Evil rebuilt trans - however, the rear ears were both broken in the accident. Also, the passenger side axle broke at the outer CV joint, due to the damage to that trailing arm. Other than the ears, there seems to be no other visible damage to the trans. - weld-on front engine mount - all other 6 conversion parts (oil tank, fittings, lines, etc.) Note there is no front cooler set up. - PMB rebuilt calipers but the passenger rear's mount is cracked. See pics. A new inner half looks like it would take care of that. - Complete 911 front end with 3.5 spacing, aluminum cross member and 20mm underside sway bar. - Rear 5-lug is drilled 914. Passenger side items likely bent. - Fuel system (tank, pump, etc) - complete wiring harness and switches. - all headlight parts, and yes, everything works. - pedal assembly, shifter, and a bunch of stuff I'm sure I'm forgetting. What's not included are items that have already been removed, as seen in the pics, plus: - wheels, interior, gauges, door handles, trunk release/hood latch, steering column, hood, trunk lid, engine lid, trunk lock. I'd greatly prefer to sell this as it sits, not part it out beyond what's been removed / the other minor parts that will be removed. It's remains on a trickle charger so that interested parties can come start it and hear it run for themselves. The price is firm. If you are seriously interested, PM me and let me know how to reach you. I'm old school and happen to find it easier to talk details. I can take additional pics and make the cold start video available to you at that point. Thanks for looking - Chris Attached thumbnail(s) |
tygaboy |
Jul 25 2020, 10:38 PM
more
tygaboy |
Jul 25 2020, 10:41 PM
and more
MikeInMunich |
Jul 26 2020, 02:35 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Awsome post! So tell us about the rollover! (IMG:style_emoticons/default/popcorn[1].gif)
Montreal914 |
Jul 26 2020, 03:54 PM
Senior Member Group: Members Posts: 1,545 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Anything to do with the rear spring assembly? (IMG:style_emoticons/default/confused24.gif) Isn't the driver's side lower spring perch reversed? Also different brand of shock passenger side to driver side? (IMG:style_emoticons/default/confused24.gif) |
tygaboy |
Jul 26 2020, 04:32 PM
(IMG:style_emoticons/default/popcorn[1].gif) Anything to do with the rear spring assembly? (IMG:style_emoticons/default/confused24.gif) Isn't the driver's side lower spring perch reversed? Also different brand of shock passenger side to driver side? (IMG:style_emoticons/default/confused24.gif) The shock mismatch is because the passenger side trailing arm and shock were damaged and removed so I could get replacements installed, just to make it movable. Note the 4 lug on that one... |
tygaboy |
Jul 26 2020, 04:33 PM
Sorry, it's not my story to tell. |
Superhawk996 |
Jul 26 2020, 07:19 PM
914 Guru Group: Members Posts: 5,780 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
The real question is who was driving it and what happened (IMG:style_emoticons/default/sad.gif) come on spill the beans!
larryM |
Jul 27 2020, 05:28 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
helluva good deal! |
Lo-Fi Version | Time is now: 8th May 2024 - 02:26 AM |
