Electrical connector tool, Cheap and easy to use |
toadman |
Jul 26 2020, 07:00 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
This cheap and easy to use tool may help someone out there who is working on their wiring. I used this today to quickly "unlock" and remove four male spade connectors from their protective plastic housings on my foglight wiring harness.
It is simply a short length of 1/16 in. hollow brass bar stock that can be purchased at most hardware stores. I smucked one end with a hammer to flatten it. Slip this flat end into the protective housing so that it slides over the locking tab. Twist it slightly while pulling gently on the wire. It will flatten the tab and the wire should pull out easily. |
lierofox |
Jul 27 2020, 03:48 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
You think we're all so loaded with cash that we can afford a hammer? (IMG:style_emoticons/default/dry.gif)
(IMG:style_emoticons/default/biggrin.gif) |
brant |
Jul 27 2020, 03:50 PM
You think we're all so loaded with cash that we can afford a hammer? (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/biggrin.gif) you could use the official 914 world hammer lender program (IMG:style_emoticons/default/drunk.gif) |
GregAmy |
Jul 27 2020, 03:58 PM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
FlacaProductions |
Jul 27 2020, 05:04 PM
Senior Member Group: Members Posts: 1,584 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
toadman |
Jul 27 2020, 05:48 PM
That is a nice tool. Didn't know it was out there. Thanks for the information.
GregAmy |
Jul 27 2020, 07:13 PM
Seriously saved my bacon when I was building a Microsquirt harness. Covers all the stock pins on the 914 plus Weatherpack, Metripack, and some Deutsch.
If you're deep into Deutsch, buy these two as well, though with your tool and the $6.49 tool you can manage: https://www.amazon.com/gp/product/B00A6AS4G6 https://www.amazon.com/gp/product/B00O7S43AE |
jd74914 |
Jul 28 2020, 06:26 AM
The all metal Deutsch pin tools are way better than the plastic 'one-time' pin removers that come with the connectors. Couple those with an HDT-48 crimper and some machined pins (yeah...I know...budget blown...) and you're cooking with gas. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 06:55 AM |
