Fuel line/hose grommet for engine tin question |
messick |
Jul 27 2020, 12:28 PM
Newbie Group: Members Posts: 39 Joined: 15-June 20 From: Orange, CA Member No.: 24,381 Region Association: Southern California |
So, replacing fuel lines and hoses in my -6 conversion, and wondering about the engine tin grommet part.
Here is a picture of where my fuel line comes from from the pump and through the tin to the fuel accumulator, and that circle slightly down and to the left is where the return hose went through. Apologies for the pine needles, I want to get the engine at least somewhat running before I drop it and trans and just clean the hell out of everything. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-24381-1595874512.1.jpg) So, I bought one "engine shelf grommet" from Tangerine Racing, since there was definitely a rotted out grommet where my return hose goes from the top of the engine, through the tin and to the return fuel line. Here's the rotted grommet: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-24381-1595874512.2.jpg) Here's the new one from Tangerine: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-24381-1595874512.3.jpg) In case you can tell from my photos, the new one is definitely not what I needed to replace the rotted one. Besides being smaller, the new one is an oval. However, since I have a '70, I have two oval holes in the front bulkhead for the fuel lines that require a grommet each, instead of a larger hole that has one grommet for both fuel lines. So I need to put that grommet plus a second one up front anyway. So, what should my engine tin grommet situation be? My current supply hardline is already going through an oval hole just like where I used my grommet up front, should that get one of these oval grommets? And if I'm doing that, should I be putting my 8mm return hose through another grommet in that empty oval hole to the upper right? Or, if I should continue to use the original ~1in round hole, where can I find a grommet that fits that? I looked around, and I couldn't any diagrams of which tin hole gets what line and what grommet. I'm actually not 100% sure these are standard holes since this is a conversion. Thanks all. |
barefoot |
Jul 27 2020, 02:51 PM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
For the oval hole, got mine from 914 Rubber.
Barefoot |
jfort |
Jul 27 2020, 03:15 PM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
on factory six (unless it was changed before I got it) the metal gas line goes through the oval hole using the grommet pictured above. I ended up replacing the metal line with a rubber one to I could add another fuel filter above the tin but the old grommet still worked
ejm |
Jul 27 2020, 03:43 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
So, what should my engine tin grommet situation be? I looked around, and I couldn't any diagrams of which tin hole gets what line and what grommet. Factory sixes didn't have CIS injection and almost every conversion is done differently. So there is no diagram of your installation. Find a place that sells an assortment of grommets, make some measurements and get what works. |
messick |
Jul 28 2020, 11:07 AM
So, what should my engine tin grommet situation be? I looked around, and I couldn't any diagrams of which tin hole gets what line and what grommet. Factory sixes didn't have CIS injection and almost every conversion is done differently. So there is no diagram of your installation. Find a place that sells an assortment of grommets, make some measurements and get what works. Yeah good point. Although, it's even worse than that, since I was originally mistaken and those holes aren't even in the engine tin, but in the body of the car itself. There was some welding done around there, and it's possible the sheet with the holes was welded in later. I don't have another 914 around to check. In any case, I'm going to try out the grommets from Tangerine, and if those don't work, I will try to find something on McMaster-Carr or whatever for that circle hole. |
messick |
Aug 4 2020, 12:04 PM
So, what should my engine tin grommet situation be? I looked around, and I couldn't any diagrams of which tin hole gets what line and what grommet. Factory sixes didn't have CIS injection and almost every conversion is done differently. So there is no diagram of your installation. Find a place that sells an assortment of grommets, make some measurements and get what works. Yeah good point. Although, it's even worse than that, since I was originally mistaken and those holes aren't even in the engine tin, but in the body of the car itself. There was some welding done around there, and it's possible the sheet with the holes was welded in later. I don't have another 914 around to check. In any case, I'm going to try out the grommets from Tangerine, and if those don't work, I will try to find something on McMaster-Carr or whatever for that circle hole. So, talked to Chris at Tangerine and turns out that 1.5" hole is for the engine tray drip tube, and since I don't have the tray, that hole was repurposed for the fuel return line. Here's the new grommet from the bird site: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-24381-1596564251.1.jpg) Here it is installed: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-24381-1596564251.2.jpg) |
Lo-Fi Version | Time is now: 15th May 2024 - 08:46 AM |
