2.7L W/ CIS to Weber 40s |
Cfletch |
Jul 27 2020, 03:24 PM
Member Group: Members Posts: 104 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
I am thinking of going to a more simpler setup for my 6 conversion. I found a set of Webers that are already jetted for a stock 2.7, which is what I have. I only need manifolds and linkage to make it all work. It seems like there were some different sized ports on the manifolds and I would like to know exactly what it is I need. Based off of my research it seems like I need 32>40 manifolds to bolt the two together. Is this correct?
I also am not having much luck on a source for them either. It does not seem like Pierce manifolds sells the manifolds and I see they sell some linkage, but it is more so generically labeled and so I am having issues being able to tell what it is that I need to purchase. Any insight will be very helpful! Thank you |
Root_Werks |
Jul 27 2020, 03:43 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I'm running CIS on my 2.7 and think it's simpler than carbs. CIS is mechanical and there's not much that can go wrong. Plus, you don't have to care much about E10 in fuel. Move to carbs and that becomes an issue.
Cfletch |
Jul 27 2020, 04:00 PM
I'm running CIS on my 2.7 and think it's simpler than carbs. CIS is mechanical and there's not much that can go wrong. Plus, you don't have to care much about E10 in fuel. Move to carbs and that becomes an issue. I generally prefer carbs on my cars and am not a rookie to tuning them once they are on, my family has a few English classics with various types on them so they do not scare me, if anything, older injection scares me mainly because of the pressure, the plumbing, my irrational fear of springing a high pressure leak because of how the lines attach to the pump/accumulator/filter. |
TravisNeff |
Jul 27 2020, 04:08 PM
Tell us more about your 2.7 engine. The 74 normal (not S) has a 32mm intake port, all years of the S model have a 35mm intake port. I have a 74 normal engine and I verified it has a 32mm intake
The 75 (S and normal) and up may all be 35mm - but I do not know that for sure |
Cfletch |
Jul 27 2020, 04:12 PM
Tell us more about your 2.7 engine. The 74 normal (not S) has a 32mm intake port, all years of the S model have a 35mm intake port. I have a 74 normal engine and I verified it has a 32mm intake The 75 (S and normal) and up may all be 35mm - but I do not know that for sure Sorry! Forgot the year, it is a 74 non S model. So it seems like my initial search was correct. Are there any vendors that sell the correct manifold for the car? It seems like Ebay is going to be my best bet unless I can stumble across the something. |
sixnotfour |
Jul 27 2020, 05:08 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Cfletch |
Jul 27 2020, 05:18 PM
Ah okay I see, they will be the full source then
roblav1 |
Jul 27 2020, 05:34 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I saw a set of original 911 weber intake manifolds on pelican yesterday. Not sure of size.
914Toy |
Jul 27 2020, 07:46 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
Stock CIS cams are not optimal for carbs - one more issue to consider.
JmuRiz |
Jul 27 2020, 08:43 PM
914 Guru Group: Members Posts: 5,429 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
+1 if the internals of the 2.7 are stock, keep the CIS and clock the fuel dist if it touches the rear bulkhead. If setup CIS is turnkey easy/simple w/o the fuss.
That was my plan until we got into the engine and found the prior rebuild was barf-tastic. |
porschetub |
Jul 27 2020, 10:12 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Stock CIS cams are not optimal for carbs - one more issue to consider. (IMG:style_emoticons/default/agree.gif) cams are very tame in these engines to work with CIS,the system has little tolerance for "flutter "of the air plate so the stock cams are what they are for that reason,I believe the piston shape in these motors isn't optimum for carbs also. Yes PMO manifolds will work or 911 carb manifolds with inlet port adaptors ,remember a guy on pelican makes them but don't remember his username. Hardly a system for power but super reliable in good condition with great starting ,driving and good fuel economy,an interim move before Porsche went to electronic FI and was first used on the last half year only 2.4 to replace MFI. |
porschetub |
Jul 27 2020, 11:02 PM
+1 if the internals of the 2.7 are stock, keep the CIS and clock the fuel dist if it touches the rear bulkhead. If setup CIS is turnkey easy/simple w/o the fuss. That was my plan until we got into the engine and found the prior rebuild was barf-tastic. Never got there thankfully. |
sixnotfour |
Jul 28 2020, 04:49 AM
there is a guy jn CA ..looking for 2.7 jetted webers ,If you change your mind..
Lo-Fi Version | Time is now: 20th May 2024 - 06:26 PM |
