I am thinking of going to a more simpler setup for my 6 conversion. I found a set of Webers that are already jetted for a stock 2.7, which is what I have. I only need manifolds and linkage to make it all work. It seems like there were some different sized ports on the manifolds and I would like to know exactly what it is I need. Based off of my research it seems like I need 32>40 manifolds to bolt the two together. Is this correct?
I also am not having much luck on a source for them either. It does not seem like Pierce manifolds sells the manifolds and I see they sell some linkage, but it is more so generically labeled and so I am having issues being able to tell what it is that I need to purchase.
Any insight will be very helpful! Thank you
