Elec Air Cond, PMS |
Coondog |
Jul 28 2020, 10:32 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
914forme |
Jul 30 2020, 07:10 AM
96a just means you will be hitting the backup storage, battery for the additional Amps. That is going to take a serious wire #4 if it is all copper, and #2 if it is an aluminum or AL - copper clad.
Example Never used the product just showing an example to make it easier on the next person. Now time to pop the (IMG:style_emoticons/default/popcorn[1].gif) |
76-914 |
Jul 30 2020, 08:37 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
96a just means you will be hitting the backup storage, battery for the additional Amps. That is going to take a serious wire #4 if it is all copper, and #2 if it is an aluminum or AL - copper clad. Example Never used the product just showing an example to make it easier on the next person. Now time to pop the (IMG:style_emoticons/default/popcorn[1].gif) Could be and I'm interested to see just like the rest of us, Stephan. Mark said his experience with them is that they are marginal which leads me to suspect they might require running on high a good amount of the time. Keith's unit will mount within 2-3ft of his battery which is also located in the front, so that helps with the wire size. An advantage that Keith will have over the units that Mark has experienced is the dry climate his will operate in. In skimming over the data for that brand unit I notice it is used for the sleeping area in a Semi Cab which, to me, would indicate night usage. There are however several larger units they sell and some of them surely can handle severe conditions, i.e. TX, OK, LA, FL, etc. I'd like to see how they perform in the heat of the day as well. Keith is a sharp cookie so I'm sure he'll cover all of the bases. So fingers crossed for his success. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 08:27 AM |
