Elec Air Cond, PMS |
Coondog |
Jul 28 2020, 10:32 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Bleyseng |
Jul 30 2020, 09:26 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
For a 4 cylinder then sourcing a 70amp bus alternator and having it rebuilt to a higher output might be the ticket to power these electric AC's.
Steve |
Jul 30 2020, 10:36 AM
914 Guru Group: Members Posts: 5,571 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
For a 4 cylinder then sourcing a 70amp bus alternator and having it rebuilt to a higher output might be the ticket to power these electric AC's. There is plenty of room for a compressor on a 4 or water cooler transplant. Why deal with an inefficient electric compressor? |
914e |
Jul 30 2020, 06:46 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
For a 4 cylinder then sourcing a 70amp bus alternator and having it rebuilt to a higher output might be the ticket to power these electric AC's. There is plenty of room for a compressor on a 4 or water cooler transplant. Why deal with an inefficient electric compressor? An electric compressor can be more efficient since it runs at constant speeds it does not have to be as large as one turned by the engine. In modern cars it is more efficient, plus you have the auto start stop engines now. A typical modern compressor is said to use about 3kW to drive it, vs the under 1kW for these electric compressors. 12 volts is still tough. The 914 has very old inefficient alternators so it likely a wash. As I remember the old long 6 cylinder GM compressors used something like 25 HP about 19kW of course it also had about 3-1/2 tons of cooling output. |
Lo-Fi Version | Time is now: 4th May 2024 - 11:35 AM |
