Elec Air Cond, PMS |
Coondog |
Jul 28 2020, 10:32 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Steve |
Jul 29 2020, 06:31 PM
914 Guru Group: Members Posts: 5,571 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Keith and I are playing around with different options all based on the Benling DM18A7 Electric compressor, aftermarket condenser, 911 condenser and off the shelf evaporators. Hopefully in a month we should be able to post something. Classic retrofit said they would sell this console evaporator separately. I am seeing the Benling electric compressor on evil bay for under $800.00. So if your a hobbyist the total solution is not that expensive if you piece mail it yourself. Do the math.... Benling compressor on the lowest setting is 40 amps + evaporator fans, condenser or oil cooler fans if your using a 911 condenser in front of your six oil cooler. A 2.7 alternator is 70 amps and a 3.2 alternator is 90 amps. With LED headlights, what else are you powering....??
This makes sense for a six conversion, for a four or water cooled power plant your better off with a standard belt driven compressor. Check out my blog for a picture of my condenser setup. The 911 condenser is about the length and height of a Mazda cooler, so you would need to modify your GT shroud to make it fit. |
Jonny Retrofit |
Aug 1 2020, 04:26 PM
Newbie Group: Members Posts: 23 Joined: 27-September 15 From: UK Member No.: 19,211 Region Association: None |
Keith and I are playing around with different options all based on the Benling DM18A7 Electric compressor, aftermarket condenser, 911 condenser and off the shelf evaporators. Hopefully in a month we should be able to post something. Classic retrofit said they would sell this console evaporator separately. I am seeing the Benling electric compressor on evil bay for under $800.00. So if your a hobbyist the total solution is not that expensive if you piece mail it yourself. Do the math.... Benling compressor on the lowest setting is 40 amps + evaporator fans, condenser or oil cooler fans if your using a 911 condenser in front of your six oil cooler. A 2.7 alternator is 70 amps and a 3.2 alternator is 90 amps. With LED headlights, what else are you powering....?? This makes sense for a six conversion, for a four or water cooled power plant your better off with a standard belt driven compressor. Check out my blog for a picture of my condenser setup. The 911 condenser is about the length and height of a Mazda cooler, so you would need to modify your GT shroud to make it fit. I have been emailing with Keith. We started ‘playing’ with these compressors five years ago. What they don’t tell you is that the current used is not just proportional to compressor speed, it is drastically affected by system pressure which of course is related to ambient temperature. It is not the case that low speed = 40A, high speed = 90A period. It varies wildly with ambient. Also, because the alternator output drops at idle, the voltage drops and the current rises which causes what we call the ‘death spiral’, which results in compressor shut off. In the race car world where these units have been used, it has taken cars out of races due to low voltage. It took 2 years of development and testing to devise a robust software control strategy to safely manage the power required dynamically. Our ECU is always trying to minimise the power used against the cooling required ( which it does using temperature sensors to assess demand ). The ECU drives the compressor at variable speeds to regulate the current consumption. We are still fine tuning the software and we release software updates based on user feedback (thanks to our customers and our Arizona and Florida partners). In a nutshell, What you are paying for is our blood, sweat and tears in developing a control system that allows the compressor to ‘play nice’, not drain your battery, not roast your alternator. Although the compressor we supply might look like others available online, it is not the same unit. |
76-914 |
Aug 2 2020, 12:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Keith and I are playing around with different options all based on the Benling DM18A7 Electric compressor, aftermarket condenser, 911 condenser and off the shelf evaporators. Hopefully in a month we should be able to post something. Classic retrofit said they would sell this console evaporator separately. I am seeing the Benling electric compressor on evil bay for under $800.00. So if your a hobbyist the total solution is not that expensive if you piece mail it yourself. Do the math.... Benling compressor on the lowest setting is 40 amps + evaporator fans, condenser or oil cooler fans if your using a 911 condenser in front of your six oil cooler. A 2.7 alternator is 70 amps and a 3.2 alternator is 90 amps. With LED headlights, what else are you powering....?? This makes sense for a six conversion, for a four or water cooled power plant your better off with a standard belt driven compressor. Check out my blog for a picture of my condenser setup. The 911 condenser is about the length and height of a Mazda cooler, so you would need to modify your GT shroud to make it fit. I have been emailing with Keith. We started ‘playing’ with these compressors five years ago. What they don’t tell you is that the current used is not just proportional to compressor speed, it is drastically affected by system pressure which of course is related to ambient temperature. It is not the case that low speed = 40A, high speed = 90A period. It varies wildly with ambient. Also, because the alternator output drops at idle, the voltage drops and the current rises which causes what we call the ‘death spiral’, which results in compressor shut off. In the race car world where these units have been used, it has taken cars out of races due to low voltage. It took 2 years of development and testing to devise a robust software control strategy to safely manage the power required dynamically. Our ECU is always trying to minimise the power used against the cooling required ( which it does using temperature sensors to assess demand ). The ECU drives the compressor at variable speeds to regulate the current consumption. We are still fine tuning the software and we release software updates based on user feedback (thanks to our customers and our Arizona and Florida partners). In a nutshell, What you are paying for is our blood, sweat and tears in developing a control system that allows the compressor to ‘play nice’, not drain your battery, not roast your alternator. Although the compressor we supply might look like others available online, it is not the same unit. Hows does it perform @ temps above 35C? Hi Way/ City? In Southern California traffic is stop n go. More stopping than going. Same goes for Austin, Dallas and Miama (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 04:26 AM |
