Removing speedo ? |
Removing speedo ? |
63acornwall |
Jul 29 2020, 05:54 AM
Member Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
Does the speedo just pull out or do you have to remove the panel it is set in ?
There must be a connection for odometer reset and speedo cable and panel bulb ? Does not appear to be a way to get at these from behind the panel Attached thumbnail(s) |
Jul 29 2020, 06:01 AM
there's a tiny screw on the odometer reset knob and a thin nut that holds the cable in under the dash.
Nojoah |
Jul 29 2020, 02:58 PM
Member Group: Members Posts: 119 Joined: 6-May 20 From: Ontario Member No.: 24,234 Region Association: Canada |
Gauge just pops out of the panel - no need to unscrew. I found it easiest to unplug the reset cable on the speedo side rather than the knob side. Just pulls out.
Lo-Fi Version | Time is now: 17th May 2024 - 07:27 AM |
