63acornwall
Jul 29 2020, 05:54 AM
Does the speedo just pull out or do you have to remove the panel it is set in ?
There must be a connection for odometer reset and speedo cable and panel bulb ?
Does not appear to be a way to get at these from behind the panel
Jul 29 2020, 06:01 AM
there's a tiny screw on the odometer reset knob and a thin nut that holds the cable in under the dash.
Nojoah
Jul 29 2020, 02:58 PM
Gauge just pops out of the panel - no need to unscrew. I found it easiest to unplug the reset cable on the speedo side rather than the knob side. Just pulls out.
