What Carbs should I get....., for my bus? |
malcolm2 |
Jul 29 2020, 09:10 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK the BUS engine is ready for tins, etc... I don't have carbs tho. I figured I would get stock-ish carbs. Air Cooled dot net experts say to go with weber 40 IDFs. My 1st thought was the Solex 34 PDSI.
Engine is TIV 1.7 built to oem 2.0. In a bus of course. Got some assume New Camper Special Heads. IIRC they are ported like the 2.0. Got the 9590 cam from Type 4 store for carbs. So what should I get? Attached thumbnail(s) |
nditiz1 |
Jul 29 2020, 10:01 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Weber 40s and some good linkage either CSP or Tangerine if you can spare the coin.
CB Performance Manifolds if buying separately. I can't remember if Johns kit comes with manifolds. I never liked the short ones. Air cleaners you can also go with the non-crossbar base, filter, and top. Go with the standard jets John provides at first which is what stock 40s come with. That will be a good starting point. You should also get a wideband so you can dial the jets in. |
IronHillRestorations |
Jul 29 2020, 10:10 PM
I'd probably go with Weber 40 IDF's too. The rub is finding a good set. I've never had my hands on the Chinese knock offs, but I haven't heard glowing reports. I'd love to see a good dyno analysis of the different ones available. There's a few different brands of import knockvoffs on Bezosmart but I'll bet they are from the same manufacturer, and reviews are iffy. I don't know how good the brand new Webers are either.
bbrock |
Jul 29 2020, 11:29 PM
I ran Weber 34 ICTs on my bus many years ago and liked them.
GregAmy |
Jul 30 2020, 06:10 AM
Advanced Member Group: Members Posts: 2,305 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
What are the good IDFs worth and how do you identify the good ones? I have a pair I may sell but I'm a Dellorto guy (40 DRLAs in my race car, with a pair of 45s tempting me).
Bleyseng |
Jul 30 2020, 09:29 AM
TheCabinetmaker |
Jul 30 2020, 09:35 AM
I thought the 9590 was a fuel injection cam?
malcolm2 |
Jul 30 2020, 11:03 AM
I thought the 9590 was a fuel injection cam? If I remember correctly the 9550 is the FI. I believe that is what I put in my 1911 cc engine in my 914. The type4 store is sorely lacking product info and descriptions, etc.... But I am pretty sure I called or emailed and told them what I was doing and they sent the RAT-9590. Still have the box, and I just checked the part# to be certain. Too many to choose from, there is no way I would have just picked it out. But if it is FI, I am stuck with it. Dirty rusty carbs. |
Jul 30 2020, 11:59 AM
Might be too late, but many, many moons ago i put a 2.0L T4 with D-Jet in my '74 bus.
That thing was a blast to drive! So my vote is D-Jet or L-Jet injection ... (IMG:style_emoticons/default/biggrin.gif) |
bbrock |
Jul 30 2020, 01:22 PM
malcolm2 |
Jul 30 2020, 01:25 PM
Might be too late, but many, many moons ago i put a 2.0L T4 with D-Jet in my '74 bus. That thing was a blast to drive! So my vote is D-Jet or L-Jet injection ... (IMG:style_emoticons/default/biggrin.gif) I did consider L-Jet. This engine is out of a 914. @Pilothyer pretty much gave me a 1.8 long block that he drove around the block and took out. I probably should have just found a FI system and put in on there. I would have been driving this bus last year. I am pretty sure, maybe 75 VW started putting L-jet in the bus. So I probably could still find one and have 2 70's cars with the same set up. Clark |
malcolm2 |
Jul 30 2020, 01:31 PM
I ran Weber 34 ICTs on my bus many years ago and liked them. Too small with Camper Special heads! Get Weber 40's Ah, good catch. I didn't notice the note about heads. I was running them on a stock motor. Again, if I remember correctly HAM makes the CS heads for Type4store that are ported like the porsche 2.0 heads. Maybe I should check with him on this set up. @HAM Inc |
porschetub |
Jul 30 2020, 03:02 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Might be too late, but many, many moons ago i put a 2.0L T4 with D-Jet in my '74 bus. That thing was a blast to drive! So my vote is D-Jet or L-Jet injection ... (IMG:style_emoticons/default/biggrin.gif) I did consider L-Jet. This engine is out of a 914. @Pilothyer pretty much gave me a 1.8 long block that he drove around the block and took out. I probably should have just found a FI system and put in on there. I would have been driving this bus last year. I am pretty sure, maybe 75 VW started putting L-jet in the bus. So I probably could still find one and have 2 70's cars with the same set up. Clark L-jet would be great if it works with your cam,I have an l-jet system and the ecu number indicates 1800 75 bus,I intend to fit it to a 411 1.7 FI motor I have. There was a change in ecu's later on. |
Bleyseng |
Jul 30 2020, 03:20 PM
Lo-Fi Version | Time is now: 20th May 2024 - 08:03 PM |
