larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
posting Q for new member 935DP Ravena green L65K needs info on formula to mix for repaint NOW |
doug_b_928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 714 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada ![]() |
I don’t have the formula but will need this as well. The local supplier says that sikkens u base (solvent) has the colour. I’m planning to get a color card from them to compare to what’s left of the original paint on my car. But it will be a while before I can get to it. I’ll watch this thread with interest.
914e |
Member ![]() ![]() Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region ![]() ![]() |
PPG should be able to match it. An old formula might not even work anymore, the pigments have changed over the years.
partsman912 |
Newbie ![]() Group: Members Posts: 7 Joined: 29-March 20 From: Maryland Member No.: 24,076 Region Association: MidAtlantic Region ![]() |
partsman912 |
Blue6 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,055 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California ![]() ![]() |
Now that’s a beautiful car. Bump
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,777 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Matcing shirt too ! Beautiful. |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,737 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Just be aware most moderns paints/clear are too bright to fully match.
I am a bit surprised the paint shop can’t look this up. @partsman912 - nice work! |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,908 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Base Paint: Dimension DM628
L65K Ravenna Green: Code: DM628 Base Paint 75.77 g DM529 Clean Yel 70.89 g DM528 Ferrite 16.63 g DM504 Yellow G 3.29 g DM522 Strong W 0.08 g Sherwin-Williams Automotive. https://www.thesamba.com/vw/forum/archive/i...-40--index.html |
partsman912 |
![]() Bottom is as nice as the top . This was the first time using Nason (you may remeber them as Dupont) paint .Always used PPG in the past but the local supplier went out of business. I must say it was wonderful to use if you go by the spec sheet directions. Car was down to bare metal used epoxy sealer first then medium build primer before putting down 3 coats of color. |
Lo-Fi Version | Time is now: 10th July 2025 - 07:02 PM |
