Dual Carbs, Idle |
Dual Carbs, Idle |
cpavlenko |
Aug 7 2020, 10:29 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Starts right up with good idle, but after a good drive when stopping for red light, it wants to start dying and drops idle real low. Like 500 or less rpm. My idle on the Weber 40's when cold is about 1200 rpm and and smooth. Any thoughts out there. 1.7 built to a 2.2. Engine has almost 600 miles since build. Other than this problem, it runs great. Oh oil temp after good run bout 210 to 220 degrees in 95 degree weather.
Ansbacher |
Aug 8 2020, 02:34 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
I was never able to get a good stable idle over the whole temperature range until I replaced my raggedy intake gaskets where the intakes meet the heads. Any air leak there causes all kinds of grief. Check your gaskets and replace if unsure of condition.
Ansbacher |
Lo-Fi Version | Time is now: 26th May 2024 - 06:03 PM |
