Speedo angle drive oil seal removal, how do you get the bas#ard out ????? |
porschetub |
Aug 8 2020, 07:11 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As per question,TIA
porschetub |
Aug 10 2020, 05:33 PM
Saga continues,found a fair amount of wear on the shaft carrier and a bit sloppy in the gearbox even with new o ring seal....PO had fitted the lock screw with a fat washer behind it so it wasn't located into the carrier enough,sorted that.
Angle drive was very loose and suspect another leak possible in that area so applied a bead of JB weld and worked well. Progress never the less and next job is to beef up one lock screw on my rear shift rod so it stays put. |
bdstone914 |
Aug 10 2020, 10:01 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@porschetub
Note the erosion on the aluminum wear it is not contacting the case. This may cause more seepage. The bottom part of the angle drive to the top normally pivots. Hope that works for you. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:05 PM |
