Alternator Question.... |
Joe Bob |
Jul 19 2003, 08:20 PM
If an alternator normally runs clock wise....would it work if it
spun the other way? My GM alternator I am using on the Type IV is not putting out juice, but it is spinning the opposite way than the alternator on my GM truck does......before I call Summitt and bitch....would this make it not charge? |
ChrisReale |
Jul 19 2003, 08:35 PM
I dont think it will work. In fact, I think it is bad for an alternator to spin the opposite way it is intended to.
Alfred |
Jul 19 2003, 09:43 PM
Unregistered |
Well, it would still be alternating current. Don't GM alternators have fans on their pulleys? Rotating the opposite direction would not help alternator cooling. Here are some alternator basics.
Alfred (IMG:http://www3.telus.net/public/alpine65/alternator490.jpg) |
Aaron Cox |
Jul 19 2003, 09:45 PM
nice post alfred- but where did mr. jeffred schwenk go? (IMG:style_emoticons/default/lol2.gif)
Alfred |
Jul 19 2003, 09:56 PM
Unregistered |
QUOTE(acox914 @ Jul 19 2003, 07:45 PM) nice post alfred- but where did mr. jeffred schwenk go? (IMG:style_emoticons/default/lol2.gif) Cox, if you're typical of your generation, I'm worried for the future. It'll be a half illiterate society in a few years. Alfred |
Aaron Cox |
Jul 19 2003, 09:59 PM
seanery |
waiting to rebuild whitey! Group: Retired Admin Posts: 15,841 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Alfred, err Kreiger,
that's not very nice. |
Alfred |
Jul 19 2003, 10:01 PM
Unregistered |
QUOTE(acox914 @ Jul 19 2003, 07:59 PM) Perfect example of what I'm talkin' about. |
Aaron Cox |
Jul 19 2003, 10:03 PM
its all fun and games-
i dont care if i get bagged on~ Honestly (sob) (IMG:style_emoticons/default/huh.gif) jk |
ChrisReale |
Jul 19 2003, 10:12 PM
I was told that when you spin your car, put your clutch in so you dont blow up your MPS (if you have FI) and so you dont fry your alternator.
Mueller |
Jul 19 2003, 11:58 PM
An alternator will produce voltage in either direction....
Joe Bob |
Jul 20 2003, 08:12 AM
So then the new alternator I bought is dead.....it only shows 12.5 volts while turning at tidle and 3,000 rpms.
Mueller |
Jul 20 2003, 08:17 AM
GM single wire? Is there a load while checking the voltage? Turn on your headlights and check the voltage.
Joe Bob |
Jul 20 2003, 08:25 AM
GM single...multi meter across the battery, 12.5 at ide AND 3,000 rpms.....meter at the alternator with accessories running, 12.5 volts. No charge.....\
http://web.media.mit.edu/~nathan/ne...alternator.html BTW...kellzey posted this link.....seems to suggest that clockwise is the other way...... (IMG:style_emoticons/default/blink.gif) |
Alfred |
Jul 20 2003, 11:40 AM
Unregistered |
Up here in Canada, we can bring an alternator in to most Canadian Tire stores and they'll test it for free. I think I heard that some of your Flaps (or similar) will do the same.
Alfred |
Joe Bob |
Jul 20 2003, 12:00 PM
I already know it does not work, I just need to know if I fried by turning it the wrong way....
Unless if by testing it and then turning it clockwise suddenly makes it work.... |
Alfred |
Jul 20 2003, 12:11 PM
Unregistered |
Do you have a multimeter? Test your diodes - it couldn't hurt.
Alfred (IMG:http://www3.telus.net/public/alpine65/diodes469.jpg) (IMG:http://www3.telus.net/public/alpine65/diodes470.jpg) |
Joe Bob |
Jul 20 2003, 12:59 PM
This is a one wire alternator.....does it have to be grounded? I see a nut on the back opposite the power wire....nothing going to it.....
Joe Bob |
Jul 20 2003, 02:45 PM
Well, here's where I f-uped......it was tested at Manny, Moe and Rice. No output....I burned the brushes by turning it backwards.
I need to go an alternator shop, have the brushes replaced and converted to CCW like a boat. GM alternators turn CW, the cooler fan needs it that way the brushes are set uyp that way....live and learn.....(IMG:style_emoticons/default/rolleyes.gif) |
Alfred |
Jul 20 2003, 03:10 PM
Unregistered |
Lo-Fi Version | Time is now: 26th April 2024 - 02:16 AM |
