Joe Bob
Jul 19 2003, 08:20 PM
If an alternator normally runs clock wise....would it work if it
spun the other way?
My GM alternator I am using on the Type IV is not putting out juice, but it is spinning the opposite way than the alternator on my GM truck does......before I call Summitt and bitch....would this make it not charge?
ChrisReale
Jul 19 2003, 08:35 PM
I dont think it will work. In fact, I think it is bad for an alternator to spin the opposite way it is intended to.
Alfred
Jul 19 2003, 09:43 PM
Well, it would still be alternating current. Don't GM alternators have fans on their pulleys? Rotating the opposite direction would not help alternator cooling. Here are some alternator basics.
Alfred
Aaron Cox
Jul 19 2003, 09:45 PM
nice post alfred- but where did mr. jeffred schwenk go?
Alfred
Jul 19 2003, 09:56 PM
QUOTE(acox914 @ Jul 19 2003, 07:45 PM)
Cox, if you're typical of your generation, I'm worried for the future. It'll be a half illiterate society in a few years.
Alfred
Aaron Cox
Jul 19 2003, 09:59 PM
oh great- then the US willl be like a second canada then
eh?
seanery
Alfred, err Kreiger,
that's not very nice.
Alfred
Jul 19 2003, 10:01 PM
QUOTE(acox914 @ Jul 19 2003, 07:59 PM)
eh?
Perfect example of what I'm talkin' about.
Aaron Cox
Jul 19 2003, 10:03 PM
its all fun and games-
i dont care if i get bagged on~ Honestly (sob)
jk
ChrisReale
Jul 19 2003, 10:12 PM
I was told that when you spin your car, put your clutch in so you dont blow up your MPS (if you have FI) and so you dont fry your alternator.
Mueller
Jul 19 2003, 11:58 PM
An alternator will produce voltage in either direction....
Joe Bob
Jul 20 2003, 08:12 AM
So then the new alternator I bought is dead.....it only shows 12.5 volts while turning at tidle and 3,000 rpms.
Mueller
Jul 20 2003, 08:17 AM
GM single wire? Is there a load while checking the voltage? Turn on your headlights and check the voltage.
Joe Bob
Jul 20 2003, 08:25 AM
GM single...multi meter across the battery, 12.5 at ide AND 3,000 rpms.....meter at the alternator with accessories running, 12.5 volts. No charge.....\
http://web.media.mit.edu/~nathan/ne...alternator.html BTW...kellzey posted this link.....seems to suggest that clockwise is the other way......
Alfred
Jul 20 2003, 11:40 AM
Up here in Canada, we can bring an alternator in to most Canadian Tire stores and they'll test it for free. I think I heard that some of your Flaps (or similar) will do the same.
Alfred
Joe Bob
Jul 20 2003, 12:00 PM
I already know it does not work, I just need to know if I fried by turning it the wrong way....
Unless if by testing it and then turning it clockwise suddenly makes it work....
Alfred
Jul 20 2003, 12:11 PM
Do you have a multimeter? Test your diodes - it couldn't hurt.
Alfred
Joe Bob
Jul 20 2003, 12:59 PM
This is a one wire alternator.....does it have to be grounded? I see a nut on the back opposite the power wire....nothing going to it.....
Joe Bob
Jul 20 2003, 02:45 PM
Well, here's where I f-uped......it was tested at Manny, Moe and Rice. No output....I burned the brushes by turning it backwards.
I need to go an alternator shop, have the brushes replaced and converted to CCW like a boat. GM alternators turn CW, the cooler fan needs it that way the brushes are set uyp that way....live and learn.....
Alfred
Jul 20 2003, 03:10 PM
Check out how Griznant did it in
this thread.
Alfred
Joe Bob
Jul 20 2003, 08:04 PM
Good idea....his also turns Clockwise. Mine is mounted assbackwards.
Alfred
Jul 20 2003, 08:18 PM
I don't understand ... how can his turn CW and yours turns CCW?
Alfred
Joe Bob
Jul 20 2003, 08:29 PM
Depends on how I was looking at the car.....
My alternator is being turned off the same crank on a REAR engined car, but the alternator is facing the same way.....but in the back......it's turned around 180 degrees .....and so am I.....
