What are these called?, And where does this go? |
bkrantz |
Aug 9 2020, 03:24 PM
914 Guru Group: Members Posts: 7,762 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
What is the proper name for these "box" connectors, single or double? The have an extra-long male spade connector fixed inside the box, and accommodate a female spade from the other end. Any sources for new ones?
Attached thumbnail(s) |
bkrantz |
Aug 9 2020, 03:27 PM
And does anyone know what this box connects to? This would be on the right side of the engine, probably below the sheet metal and near the fuel pump. My fuel pump wires are already gone, relocated to head to the front. The rest of the wires in that bundle go to the battery.
Mark Henry |
Aug 9 2020, 06:18 PM
2nd pic is likely the fuel pump with the proper connector cut off and the "box connector" is the taco plate temp sensor wire to console connection.
Mikey914 |
Aug 9 2020, 07:22 PM
The rubber man Group: Members Posts: 12,665 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
And does anyone know what this box connects to? This would be on the right side of the engine, probably below the sheet metal and near the fuel pump. My fuel pump wires are already gone, relocated to head to the front. The rest of the wires in that bundle go to the battery. The wires shown connect to the battery with one of these It goes through and tightens down at the battery post and the block is where the wires connect https://914rubber.com/battery-block-positive-terminal-1 Attached thumbnail(s) Attached image(s) |
bkrantz |
Aug 9 2020, 07:58 PM
2nd pic is likely the fuel pump with the proper connector cut off and the "box connector" is the taco plate temp sensor wire to console connection. Thanks, Mark. The fuel pump wires are missing because I have already re-routed them for a front pump relocation. Another stupid question: what is the taco plate? |
ClayPerrine |
Aug 9 2020, 08:42 PM
Would it be possible to get a close up of the wires so we can see the color?
Jonathan Livesay |
Aug 9 2020, 09:39 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
First picture looks like the tunnel wires that connect to the center console gauges. Second picture might be the red wires that connect to the battery + side. Hard to get a sense of scale from the picture but these would be large gauge wires.
djway |
Aug 9 2020, 10:07 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
http://www.wolfsburgwest.com/cart/DetailsL...fm?ID=111937077
Wolfsburg West sells them. They come all attached and you cut to the number you want. |
Mark Henry |
Aug 10 2020, 05:19 AM
And does anyone know what this box connects to? This would be on the right side of the engine, probably below the sheet metal and near the fuel pump. My fuel pump wires are already gone, relocated to head to the front. The rest of the wires in that bundle go to the battery. The wires shown connect to the battery with one of these It goes through and tightens down at the battery post and the block is where the wires connect https://914rubber.com/battery-block-positive-terminal-1 The wires to the + battery are 10 gauge, those don't look heavy enough, I believe the main part of that harness (down) has the connectors (red wires) to the + battery. But I could be wrong... it's hard to tell the gauge or colour in the pic. Looking at my '74 teen the heavy wires to the battery route the same side/harness as the fuel pump wires, but I don't feel like yanking at my wires to find out 100%. |
iankarr |
Aug 10 2020, 07:52 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
2nd pic is likely the fuel pump with the proper connector cut off and the "box connector" is the taco plate temp sensor wire to console connection. Thanks, Mark. The fuel pump wires are missing because I have already re-routed them for a front pump relocation. Another stupid question: what is the taco plate? The taco plate protects the oil sump cover, which houses the temp sender. Legend has it that it got the "taco" name because it likes to bend, like a.... |
bkrantz |
Aug 10 2020, 09:04 PM
http://www.wolfsburgwest.com/cart/DetailsL...fm?ID=111937077 Wolfsburg West sells them. They come all attached and you cut to the number you want. Thanks, but they are not exactly the same. The stock 914 connector is a box, single or double, that has a double-length male spade that is fixed inside with a locking tab. A normal female spade can then plug in to the other end of the box. The VW style has a permanent double male inside the box, and takes female spades from both ends. |
bkrantz |
Aug 10 2020, 09:06 PM
And does anyone know what this box connects to? This would be on the right side of the engine, probably below the sheet metal and near the fuel pump. My fuel pump wires are already gone, relocated to head to the front. The rest of the wires in that bundle go to the battery. The wires shown connect to the battery with one of these It goes through and tightens down at the battery post and the block is where the wires connect https://914rubber.com/battery-block-positive-terminal-1 The wires to the + battery are 10 gauge, those don't look heavy enough, I believe the main part of that harness (down) has the connectors (red wires) to the + battery. But I could be wrong... it's hard to tell the gauge or colour in the pic. Looking at my '74 teen the heavy wires to the battery route the same side/harness as the fuel pump wires, but I don't feel like yanking at my wires to find out 100%. Mark, on mine (and I think the wires are stock, even if one loop connector is not), there are 2 pairs. In each pair I see a 10 gauge and a 12 gauge (or the mm equivalents). |
bkrantz |
Aug 10 2020, 09:08 PM
2nd pic is likely the fuel pump with the proper connector cut off and the "box connector" is the taco plate temp sensor wire to console connection. Thanks, Mark. The fuel pump wires are missing because I have already re-routed them for a front pump relocation. Another stupid question: what is the taco plate? The taco plate protects the oil sump cover, which houses the temp sender. Legend has it that it got the "taco" name because it likes to bend, like a.... Thanks, Ian. I am pretty sure there was nothing plugged into the box connector when I got the car. |
bkrantz |
Aug 10 2020, 09:09 PM
Mikey914 |
Aug 10 2020, 09:10 PM
The wires here look stock and should be just fine. The connector on one side has been replaced I would make sure is a sold connection but other than that good to go.
Lo-Fi Version | Time is now: 15th May 2024 - 05:14 PM |
