Piston barrel spacers, Spacers |
simonjb |
Aug 11 2020, 09:23 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Forgiven me if a stupid q....
I am re-building my 1974 2.0 and following the manuals and Raby video. As I measure the deck height, I am too close - about .15” I have some spacers, but it appears they only fit correctly on the head side and not on the case side of the barrel. They are too small if I try to install between the barrel and the case. I am using AA pistons and 96 size Is it ok to add the spacers on top of the barrel instead of below to add the necessary height? |
iankarr |
Aug 11 2020, 09:31 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The general consensus is no. Whether or not head "gaskets" shold be used at all is a topic of debate. Google it and you'll see. They definitely make cylinder barrel "shims" in a variety of sizes. Doesn't matter if the jugs are 94mm or 96mm...if they fit properly in the case, the shims will work. And that's about as much engine advice as I'm qualified to give (IMG:style_emoticons/default/smile.gif).
How are you measuring the deck height? Are you using a specific tool? dial gauge? I'm sure if you post a pic of your setup, the engine gurus can offer more insight. |
iankarr |
Aug 11 2020, 09:36 PM
Superhawk996 |
Aug 12 2020, 07:28 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I am re-building my 1974 2.0 and following the manuals and Raby video. As I measure the deck height, I am too close - about .15” @simonjb Need clarification. 0.15" is not too close. That is a lot of deck height. 0.15mm on the other hand is way to little. Deck hight sould be in neighborhood of 0.040" Forty thousands of an inch or about 1mm. 0.15" of deck hight is beyond TRIPLE that minimum deck height of 0.040" |
Superhawk996 |
Aug 12 2020, 08:42 AM
I am re-building my 1974 2.0 and following the manuals and Raby video. As I measure the deck height, I am too close - about .15” Need clarification. 0.15" is not too close. That is a lot of deck height. 0.15mm on the other hand is way to little. Deck hight sould be in neighborhood of 0.040" Minimum. Forty thousands of an inch or about 1mm. Maximum is more like 0.060" unless you've got something unusual going on to manage compression ratio. 0.15" of deck hight is beyond TRIPLE that minimum deck height of 0.040" |
simonjb |
Aug 12 2020, 11:10 AM
sorry...I meant .015 !!!!! Thanks....
iankarr |
Aug 12 2020, 11:19 AM
Easier to have less than more, for sure.
Since I've now been through two 2056 builds with AA pistons and jugs where the deck height out of the box is over .070, I'm wondering if maybe you got a new (better) set of castings...or if the rig you're using to measure is giving different readings. How exactly are you measuring DH? |
jsaum |
Aug 12 2020, 03:20 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
How did you adjust the deck height for .070?
iankarr |
Aug 12 2020, 03:52 PM
That’s just the way it came up with the AA pistons. When I switched to KB pistons the deck height (with no shims) measured a much more normal .030
simonjb |
Aug 12 2020, 06:46 PM
So I tried again tonight and also installed the stock sealing ring between the barrel and the case. I tightened down the barrel and then turned the crank to get TDC. First one was .033. I did it again on another and got .034. The method I used was a straight edge solid metal bar across the barrel top and then used detached feeler gauges to slide under the bar until there was no resistance.
type2man |
Aug 12 2020, 06:55 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
European motor works has what you need. Or you could try calling Raby since he made the video. He should have tech support. Call him.
wndsrfr |
Aug 12 2020, 07:02 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
When you do order the shims, my advice from experience is to get two sets. Measure them after removing the burr on the inner edge from the stamping process. I found a significant variation within one pack so had to take one from the other pack to get four of the same thickness.
porschetub |
Aug 12 2020, 07:36 PM
I am re-building my 1974 2.0 and following the manuals and Raby video. As I measure the deck height, I am too close - about .15” Need clarification. 0.15" is not too close. That is a lot of deck height. 0.15mm on the other hand is way to little. Deck hight sould be in neighborhood of 0.040" Minimum. Forty thousands of an inch or about 1mm. Maximum is more like 0.060" unless you've got something unusual going on to manage compression ratio. 0.15" of deck hight is beyond TRIPLE that minimum deck height of 0.040" Wise words,however the OP hasn't mentioned a target compression ratio ?,didn't someone mention the AA barrels are too long to get correct deck height and require machining @ the case register ??. You can do head gasket delete if you so desire but heads need to be flycut for that so the seal is 100% and only if the barrel heights are equal and no erosion of the case registers. Good luck. |
Lo-Fi Version | Time is now: 15th May 2024 - 05:55 PM |
