GM's Turbo 4 Cyl engine, used in the Pontiac Solstice in M.Y. 2007 |
flmont |
Aug 11 2020, 10:35 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Does anyone have any experience with this engine, a twin screwed 4 cyl turbo used in the Solstice and the Saturn Sky the 2 seater's sports car.. rated at 260 HP, Thanks, Frank (IMG:style_emoticons/default/confused24.gif)
Mark Henry |
Aug 12 2020, 05:55 AM
My son has a 2007 cobalt SS, 2.0 supercharged LSJ engine, 210hp.
Typical GM engine electrical/sensor issues, weak coils, dealer service is useless. I believe the turbo engines have simular issues. Saab trans is OK but weak if you abuse it, that's if it has the F37. Lots of go fast goodies from ZZP here. |
Mueller |
Aug 12 2020, 09:43 AM
A member here just put one of those engines in his 914, should be good for 300+ hp.
I have a co-worker that builds these Ecotec motors, he recently bought a CNC mill that is large enough to put the block on the table to bore out the old liners for custom cylinder liners. |
brant |
Aug 12 2020, 10:28 AM
Neighbor has a cobalt drag car with this motor
but over 400hp |
flmont |
Aug 12 2020, 02:33 PM
Mr. Mueller, So it fits a 914..nicely... or do you know how well that install went ? Thanks,. Frank
1adam12 |
Aug 12 2020, 02:39 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
I believe Rhys Millen was the first to modify one of these engines when he campaigned a Solstice for Formula Drift way, way back. I remember him saying that the engine was capable of doing 500+ but I can't remember all the details from that convo. Try and find his build online, should be a few features on it.
Mueller |
Aug 12 2020, 02:47 PM
He might have more pictures, this is the only one I could find right now:
http://www.914world.com/bbs2/index.php?s=&...t&p=2678927 |
flmont |
Aug 12 2020, 02:50 PM
+ Thanks Guys..!!
Mark Henry |
Aug 12 2020, 02:54 PM
If you look many a baja bug and sand rail owner has used the ecotec engine, one of the big reasons is it doesn't weigh much more than a type one engine. IIRC it's about 250lbs dry.
KEP makes an VW trans adapter for it. |
flmont |
Aug 12 2020, 05:51 PM
Thanks Mark..I was just about to go there and look for it..T.Y,.!! Frank
Lo-Fi Version | Time is now: 15th May 2024 - 06:43 PM |
