Steering Wheel Housing Removal |
ghia1974 |
Aug 12 2020, 12:01 PM
Newbie Group: Members Posts: 14 Joined: 6-August 15 From: New Jersey Member No.: 19,033 Region Association: MidAtlantic Region |
In the process of replacing my ignition switch and ignition lock on my 73. I have taken everything apart and removed the lock assembly. I removed the Allen bolt holding on the steering wheel housing but it doesn’t pull off. Not sure if I have to further disassemble the steering column starting with the removal of the large snap ring or is the housing just stuck and may need some persuasion. Definitely will make putting the connector on the ignition switch much easier with it off the column. Please help.
ghia1974 |
Aug 13 2020, 05:19 AM
Knee pad removed and the 3 connectors. The turn sign and wiper switches removed, ignition switch/lock assembly removed and Allen bolt holding housing removed still housing does not slide off. What else needs to be done to pull housing off? Would make it easier to plug ignition switch connector back in, hard to do it with steering wheel housing in place, don’t want to damage switch connectors.
Lo-Fi Version | Time is now: 16th May 2024 - 02:26 AM |
