123Distributor install question. |
JMT |
Aug 12 2020, 01:28 PM
Newbie Group: Members Posts: 36 Joined: 19-August 16 From: Ca Member No.: 20,316 Region Association: None |
After installing the 123Distributor and turning the body CCW until the green light turns on this is where the rotor and #1 plug wire line up at TDC. Since the rotor turns clockwise it's already passed the #1 plug wire. Does it have to be pointing exactly at #1 plug or just in the general area to start the engine?
Not_A_Six |
Aug 12 2020, 08:17 PM
Member Group: Members Posts: 110 Joined: 28-November 18 From: North Idaho Member No.: 22,682 Region Association: Pacific Northwest |
After installing the 123Distributor and turning the body CCW until the green light turns on this is where the rotor and #1 plug wire line up at TDC. Since the rotor turns clockwise it's already passed the #1 plug wire. Does it have to be pointing exactly at #1 plug or just in the general area to start the engine? You only have to line the LED up good enough for the engine to start. After that, you should rotate the distributor and set the timing with a light at whatever the appropriate advance/rpm is for your engine. Have fun. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 01:56 PM |
