Any luck with Costco batteries? |
andrewck |
Aug 16 2020, 08:22 AM
Newbie Group: Members Posts: 48 Joined: 5-July 20 From: Denver Member No.: 24,461 Region Association: Rocky Mountains |
On my phone so maybe my ability to search is impaired, but saw that many of you are running Odyssey PC680 or PC1200, or Optima 34R. Has anybody run a Costco battery (Interstate I believe)? Any guidance on size or quality?
fiacra |
Aug 16 2020, 10:39 AM
Person.Woman.Man.Camera.TV Group: Members Posts: 325 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
On my phone so maybe my ability to search is impaired, but saw that many of you are running Odyssey PC680 or PC1200, or Optima 34R. Has anybody run a Costco battery (Interstate I believe)? Any guidance on size or quality? The short answer: No. I took a short trip down that path and realized it was going nowhere. The slightly longer answer: Get a sealed battery and help minimize the risk of battery acid causing a problem. Lots of good threads on what batteries work well. Also, lots of conflicting advice! Forgive me if you already know this but using google to search the site seems to work the best. Simply add "914world" to the search terms and you should get results. Good luck! |
Amphicar770 |
Aug 16 2020, 10:43 AM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Agree with previous post.
Costco, or other lead acid batteries, fine for your regular cars. Stick to sealed / AGM type for 914 and never have to worry about battery acid damaging the hell hole. I've gotten 10+ years out of my AGM batteries. |
Mark Henry |
Aug 16 2020, 11:55 AM
On my phone so maybe my ability to search is impaired, but saw that many of you are running Odyssey PC680 or PC1200, or Optima 34R. Has anybody run a Costco battery (Interstate I believe)? Any guidance on size or quality? The commonly used Odyssey battery would be the PC925. I run a PC680 in my 3.0, 10.1CR six with no issues. The downside to Odyssey and most sealed batteries is you must buy or fabricate a mount. I could see running a bigger battery for a HP stereo, but most of the time I listen to the beautiful music the weber /6 makes. |
Amphicar770 |
Aug 16 2020, 01:05 PM
Will have to check what Optima I have but it was a drop in replacement. Did not need to fabricate a mount.
thelogo |
Aug 16 2020, 01:50 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
You can use those. But if youre gonna park it for more them 2 weeks .
Remove the battery if not .... I think u know where that leads . ran when Parked : 99% rust free (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/av-943.gif) |
fiacra |
Aug 16 2020, 02:17 PM
I followed the lead of @rfinegan and put in a PC925 (see below for link to thread). No problems so far. Total cost of just over $220 for the battery, terminals, and the mount (got the battery and terminals on Amazon and the mount on eBay). However, took about two weeks for the battery and then the mount to arrive so if you are looking to replace it today.....probably won't work out. If I was in a rush I probably would have just stolen the battery from my wife's car (IMG:style_emoticons/default/happy11.gif)
http://www.914world.com/bbs2/index.php?sho...347175&st=0 |
Mark Henry |
Aug 16 2020, 05:26 PM
Will have to check what Optima I have but it was a drop in replacement. Did not need to fabricate a mount. I'd be careful with this, I had a customer who just dropped it in and the holder J-mold sawed right through one of the cells. If the battery still moves around after clamping it down it's a recipe for disaster. I used some Trim-Lok Edge Trim on the j-mold with my old Optima, it filled up the gap making for a solid install and added some protection from the sharp edge of the stock holder. |
andrewck |
Sep 6 2020, 08:51 PM
I followed the lead of @rfinegan and put in a PC925 (see below for link to thread). No problems so far. Total cost of just over $220 for the battery, terminals, and the mount (got the battery and terminals on Amazon and the mount on eBay). However, took about two weeks for the battery and then the mount to arrive so if you are looking to replace it today.....probably won't work out. If I was in a rush I probably would have just stolen the battery from my wife's car (IMG:style_emoticons/default/happy11.gif) http://www.914world.com/bbs2/index.php?sho...347175&st=0 Ended up doing this exact setup, so thank you. Battery is in the mount, but doesn't look like the tie down has a good place to attach. Do you have a photo of your installed setup so I can see where your bracket sits? |
Chris914n6 |
Sep 6 2020, 09:33 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Will have to check what Optima I have but it was a drop in replacement. Did not need to fabricate a mount. I'd be careful with this, I had a customer who just dropped it in and the holder J-mold sawed right through one of the cells. If the battery still moves around after clamping it down it's a recipe for disaster. I used some Trim-Lok Edge Trim on the j-mold with my old Optima, it filled up the gap making for a solid install and added some protection from the sharp edge of the stock holder. Back when I had an Optima all I had to do was email Optima and ask for a Group 78 hold down. They sent a meaty plastic piece that replaced the metal bracket and worked great. quick google for a pic (IMG:style_emoticons/default/biggrin.gif) thread |
Amphicar770 |
Sep 7 2020, 08:33 AM
Will have to check what Optima I have but it was a drop in replacement. Did not need to fabricate a mount. I'd be careful with this, I had a customer who just dropped it in and the holder J-mold sawed right through one of the cells. If the battery still moves around after clamping it down it's a recipe for disaster. I used some Trim-Lok Edge Trim on the j-mold with my old Optima, it filled up the gap making for a solid install and added some protection from the sharp edge of the stock holder. Thanks. It's been a while since I out it in there. In retrospect, while I did not need a custom mount, I did take a hacksaw and trimmed off some of the plastic on bottom of battery. It then fit great, locked in there nice and tight. |
windforfun |
Sep 7 2020, 02:07 PM
Senior Member Group: Members Posts: 1,785 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
So far so good.
Attached thumbnail(s) |
76-914 |
Sep 8 2020, 05:25 PM
This post reminded me to add ~4oz water to my 6 yo Costco lead/acid battery. (IMG:style_emoticons/default/biggrin.gif) My car gets wet once every 3-4 years and the battery sits in a plastic tray so the cheap ones work for me. (IMG:style_emoticons/default/beerchug.gif)
fiacra |
Sep 8 2020, 10:24 PM
I followed the lead of @rfinegan and put in a PC925 (see below for link to thread). No problems so far. Total cost of just over $220 for the battery, terminals, and the mount (got the battery and terminals on Amazon and the mount on eBay). However, took about two weeks for the battery and then the mount to arrive so if you are looking to replace it today.....probably won't work out. If I was in a rush I probably would have just stolen the battery from my wife's car (IMG:style_emoticons/default/happy11.gif) http://www.914world.com/bbs2/index.php?sho...347175&st=0 Ended up doing this exact setup, so thank you. Battery is in the mount, but doesn't look like the tie down has a good place to attach. Do you have a photo of your installed setup so I can see where your bracket sits? Check post #12 and #14 of Robert's original thread for some pics. I used a hold down I scavenged from the bone yard. Won't be able to get some pictures of my car until this week-end at the earliest. Maybe @rfinegan has some pictures/insight? |
Gint |
Sep 9 2020, 11:51 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Cheap ass autozone group 42 lead acid battery in my 914 for ... I can't even remember how many years. Works just fine. The car almost never gets wet.
Lo-Fi Version | Time is now: 16th May 2024 - 06:49 AM |
