Gauging Interest: GT Oil-cooler Fan support |
RiqueMar |
Aug 19 2020, 12:49 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Hi All,
I've received several messages and seems there is some interest in a recent fan/shroud support I created for my 3.6 project. Sending this thread out to gauge interest in producing a run of these, photos of the prototype below (shown in ABS).... Generalities: - 16 gauge steel, easily customizable for each build, and allows the 'garage builder' to weld - Added 1" on top and bottom. The user/myself can either bend the top and bottom to be used as an additional air-direct for pusher/puller fans, or as a support for aluminum/fiberglass shroud OR the excess can be trimmed to more accurately reflect the below photo. - In production now, 1-2 week to delivery - Targeting 'initial run' price of $120 per piece, will increase. |
Luke M |
Jan 18 2021, 06:21 PM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
The bracket and three fans fit under a GT cooler shroud w/o mods?
RiqueMar |
Jan 18 2021, 07:01 PM
The bracket and three fans fit under a GT cooler shroud w/o mods? @Luke M - You'll notice from the photos that the shroud itself is only a little-bit larger than the cooler, .125" top and bottom. I'm attaching a few pictures of the mount I fabricated for my cooler to make it easily removable. Studs are M8, and allow the user to add a isolator and reduce vibration, I'll admit I went a bit overkill, but it was fun. If there is enough interest, happy to make these mounting brackets as well, I have the designs in my notes. (IMG:style_emoticons/default/welder.gif) Hopefully, this will pick up enough, and I can justify pulling a mold for the shroud. I added tabs to eliminate sheet-metal screws, making it both easier to mount (off the body instead of the cooler) and overall cleaner. (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:24 PM |
