Gauging Interest: GT Oil-cooler Fan support |
RiqueMar |
Aug 19 2020, 12:49 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Hi All,
I've received several messages and seems there is some interest in a recent fan/shroud support I created for my 3.6 project. Sending this thread out to gauge interest in producing a run of these, photos of the prototype below (shown in ABS).... Generalities: - 16 gauge steel, easily customizable for each build, and allows the 'garage builder' to weld - Added 1" on top and bottom. The user/myself can either bend the top and bottom to be used as an additional air-direct for pusher/puller fans, or as a support for aluminum/fiberglass shroud OR the excess can be trimmed to more accurately reflect the below photo. - In production now, 1-2 week to delivery - Targeting 'initial run' price of $120 per piece, will increase. |
Bucci |
Jan 23 2021, 01:00 AM
Bucci Group: Members Posts: 106 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California |
It would be nice if you opened up the “air” exit on the bottom floor of the trunk. The louver slot openings are tiny. The exit side should be twice the size of of the opening, less pressure more flow.
In fact, I bent the floor sheet metal down on the leading edge of the air exit to help suck out the air creating a suction. Its the same theory as the little plastic flappers on the bottom of the car at the engine bay..! |
mb911 |
Jan 23 2021, 07:17 AM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
It would be nice if you opened up the “air” exit on the bottom floor of the trunk. The louver slot openings are tiny. The exit side should be twice the size of of the opening, less pressure more flow. In fact, I bent the floor sheet metal down on the leading edge of the air exit to help suck out the air creating a suction. Its the same theory as the little plastic flappers on the bottom of the car at the engine bay..! (IMG:style_emoticons/default/agree.gif) but it is what most people have. |
Bucci |
Jan 23 2021, 05:03 PM
Ben, I did my fabrication 21 years ago durning the restoration. I just mimic the factory design. No fans, no over heating problems ever. I’ll add pics below.
Unlike Armando‘s, all sheet metal openings that I cut on the car I retained a return edge of the 90° angle to create structure. Armando has a very good write up of his journey to duplicate the factory design. He spent all kinds of money fabricating his design. https://forums.pelicanparts.com/porsche-914...-project-5.html Armando‘s design Factory tow hook design I believe. It would be nice if you opened up the “air” exit on the bottom floor of the trunk. The louver slot openings are tiny. The exit side should be twice the size of of the opening, less pressure more flow. In fact, I bent the floor sheet metal down on the leading edge of the air exit to help suck out the air creating a suction. Its the same theory as the little plastic flappers on the bottom of the car at the engine bay..! (IMG:style_emoticons/default/agree.gif) but it is what most people have. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:12 PM |
