| rosenfe |
Aug 23 2020, 03:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 565 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
I plant to clean top,not sand. Any recommendations for spray paint choice in black
| IronHillRestorations |
Aug 23 2020, 06:55 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,922 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Clean it with a strong mix of soap and water a couple times, maybe even add a little TSP in it if you've got it.
Then I'd go over it with solvent cleaner like PreSol, Klix88, or Acme Solvent cleaner. Use two rags, one with the solvent and the other to wipe off. Change rags as they get dirty and don't stop cleaning until you wipe and your wipe off rag is clean. This doesn't mean you still won't have trouble with oil spotting, because you may. 45+ year old fiberglass roofs have be coated with Armorall, wax, shoe polish, silicone, and a host of other treatments that can impregnate the fiberglass. Your best pre-paint action is to clean, clean, and clean more. In a perfect world, you'd use an catalyzed, flattened (to the right level of low sheen), automotive finish type paint, but that's not always practical. I've got a car in my shop right now that needs the roof painted, and we're going to try a single stage rattle can epoxy VHT Epoxy All Weather Satin Black VHT Satin Black Epoxy I've been using it on suspension components and engine tins, and I like the finish and how it goes on. Time will only tell how durable it really is. Anything in a rattle can probably won't be as good as "real" auto paint, but ease of use is a plus. I get it from my local NAPA store. Online retailers may have it, but some really over charge for it |
| Tdskip |
Aug 23 2020, 08:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Super helpful post as usual, thanks @IronHillRestorations
| Tonyooc |
Aug 23 2020, 08:59 PM
1974 2.0 ![]() ![]() ![]() Group: Members Posts: 856 Joined: 6-January 18 From: Fort Mill, SC Member No.: 21,763 Region Association: South East States
I sprayed mine with a product called Raptor. You can find it in paint shops or Amazon. I sprayed my valance and spoilers the same
| Montreal914 |
Aug 23 2020, 09:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,054 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
| PCH |
Aug 23 2020, 11:34 PM
Member ![]() ![]() Group: Members Posts: 146 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California
After cleaning, sprayed mine with a rattle can. Used SEM Landau Black. Came out beautiful! But the plastic was so dry that it soaked up 3 cans of paint!
| Lucky9146 |
Aug 24 2020, 12:01 AM
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California
Had great results with SEM Trim Black. Cleaned top with Prep-sol, no sanding, no primer, just right over the existing texture that was there. Provides a nice sheen but not shiny.
You must keep a wet edge, which is difficult with a rattle can, but can be done. You will need 2-3 coats. Have received lots of complements on it. Good luck! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
Aug 24 2020, 03:49 PM
Had great results with SEM Trim Black. Cleaned top with Prep-sol, no sanding, no primer, just right over the existing texture that was there. Provides a nice sheen but not shiny. You must keep a wet edge, which is difficult with a rattle can, but can be done. You will need 2-3 coats. Have received lots of complements on it. Good luck! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) That really looks nice! SEM stuff is good. |
| Nojoah |
Aug 24 2020, 05:46 PM
Member ![]() ![]() Group: Members Posts: 119 Joined: 6-May 20 From: Ontario Member No.: 24,234 Region Association: Canada |
Had great results with SEM Trim Black. Cleaned top with Prep-sol, no sanding, no primer, just right over the existing texture that was there. Provides a nice sheen but not shiny. You must keep a wet edge, which is difficult with a rattle can, but can be done. You will need 2-3 coats. Have received lots of complements on it. Good luck! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) I second the SEM trim black. Mine turned out great as well, sprays nicely out of the can. I've also had similar results with the wurth trim black counterpart as well. You should be looking for a satin finish. |
| StarBear |
Dec 3 2022, 09:36 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,241 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Clean it with a strong mix of soap and water a couple times, maybe even add a little TSP in it if you've got it. Then I'd go over it with solvent cleaner like PreSol, Klix88, or Acme Solvent cleaner. Use two rags, one with the solvent and the other to wipe off. Change rags as they get dirty and don't stop cleaning until you wipe and your wipe off rag is clean. This doesn't mean you still won't have trouble with oil spotting, because you may. 45+ year old fiberglass roofs have be coated with Armorall, wax, shoe polish, silicone, and a host of other treatments that can impregnate the fiberglass. Your best pre-paint action is to clean, clean, and clean more. In a perfect world, you'd use an catalyzed, flattened (to the right level of low sheen), automotive finish type paint, but that's not always practical. I've got a car in my shop right now that needs the roof painted, and we're going to try a single stage rattle can epoxy VHT Epoxy All Weather Satin Black VHT Satin Black Epoxy I've been using it on suspension components and engine tins, and I like the finish and how it goes on. Time will only tell how durable it really is. Anything in a rattle can probably won't be as good as "real" auto paint, but ease of use is a plus. I get it from my local NAPA store. Online retailers may have it, but some really over charge for it @IronHillRestorations Thinking of my winter projects and painting my targa top - searched and found your suggestion. Mine is original, texture is fine but bunches of various spots over the years. Was wondering - your suggestion is lots of soap and water: dishsoap? something milder? stronger? Also, a thread on Pelican suggests using alcohol. Your thoughts? Like many others, the top has many years of treatment, black shoe polish, and lately small dots of black Sharpie, so probably lots of hidden pockets of gunk in the texture valleys. Finally, I use Wurth Satin Black for trim - OK for the top, or do the SEM Trim Satin? Thanks! |
| 930cabman |
Dec 3 2022, 10:59 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,533 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
If I recall correctly BBrock did his a year or so ago, I am unsure how to find it.
| nivekdodge |
Dec 3 2022, 11:26 PM
Member ![]() ![]() Group: Members Posts: 331 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
Sem 39144 is the same trim black in qt liquid form.They also sell "hot rod black" in kits HR010 which would be the "Porsche" of semi gloss black , and its just me, but the least I would do is a red scotch brite pad.
Kevin |
Dec 4 2022, 07:20 AM
@StarBear I suggest a stronger detergent than dish soap. Diluted Simple Green or Purple Power is going to clean better, tri sodium phosphate is really good too. Scrub with a soft bristle brush and rinse with clean water, at least twice. I used a commercial auto body cleaning solvent like Prep Sol or Klix 88 after that. Alcohol won’t cut wax and silicones good enough. I would use the scuff pads that are finer than the 3m red, I think they are gray.
I recently spoke with the owner of the car I used the spray can VHT satin black on, and he said it still looks good. |
| StarBear |
Dec 4 2022, 08:58 AM
@StarBear I suggest a stronger detergent than dish soap. Diluted Simple Green or Purple Power is going to clean better, tri sodium phosphate is really good too. Scrub with a soft bristle brush and rinse with clean water, at least twice. I used a commercial auto body cleaning solvent like Prep Sol or Klix 88 after that. Alcohol won’t cut wax and silicones good enough. I would use the scuff pads that are finer than the 3m red, I think they are gray. I recently spoke with the owner of the car I used the spray can VHT satin black on, and he said it still looks good. Thanks! Nervous about doing this, but at least a good cleaning is worthwhile. Would a quart of Prep-Sol be enough? So far, have seen it only in gallons. |
Dec 5 2022, 07:19 AM
@StarBear I suggest a stronger detergent than dish soap. Diluted Simple Green or Purple Power is going to clean better, tri sodium phosphate is really good too. Scrub with a soft bristle brush and rinse with clean water, at least twice. I used a commercial auto body cleaning solvent like Prep Sol or Klix 88 after that. Alcohol won’t cut wax and silicones good enough. I would use the scuff pads that are finer than the 3m red, I think they are gray. I recently spoke with the owner of the car I used the spray can VHT satin black on, and he said it still looks good. Thanks! Nervous about doing this, but at least a good cleaning is worthwhile. Would a quart of Prep-Sol be enough? So far, have seen it only in gallons. Probably won’t need more than a pint or two. Any good auto repair pre paint cleaner solvent will work. |
| mlindner |
Dec 5 2022, 08:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,743 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
I need to paint mine also, but I need to get back to the original texture first. Any good product or techniques for that.
| dr914@autoatlanta.com |
Dec 5 2022, 09:03 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| Root_Werks |
Dec 5 2022, 10:18 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,913 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
The top that came with my 914 was so bad, it was tossed. Sourced a decent one from @914Werke , cleaned it with soap and water. Then mineral spirits, then rattle canned SEM Trim Black.
Turned out way nicer than I thought it would. Sheen seems like a spot on match and it's held up very well so far. Others have said already: Clean and prep is key If you rattle can, keep a wet edge Have enough cans, 2 for me, 2 coats |
| windforfun |
Dec 5 2022, 07:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,095 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
I plant to clean top,not sand. Any recommendations for spray paint choice in black I didn't know that you could plant these things. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
| StarBear |
Dec 12 2022, 01:15 PM
Refresh done!
Followed suggestions posted here. Used liquid sandpaper to degloss, Simple Green followed by substitute TSP, SEM spray prep solv (1/2 can for 3 wipe downs), and SEM satin trim black (2 light coats followed by 1 medium coat; just short of one can). Whew! Pleased with result. Was nervous about messing up the top. Fortunately, texture was still fine. ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 07:50 PM |
