Big Len |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,770 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region ![]() |
rbzymek |
Member ![]() ![]() Group: Members Posts: 199 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest ![]() ![]() |
What could possibly go wrong?
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,039 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Looks like it will do a good job at circulating the exhaust gases and hot air from the engine. Safe enough with no guard. |
ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,163 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
I saw this over the weekend - Prop NOT included. (IMG:style_emoticons/default/confused24.gif)
What the heck was that thing cooling? (IMG:style_emoticons/default/confused24.gif) |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,609 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
I saw this over the weekend - Prop NOT included. (IMG:style_emoticons/default/confused24.gif) What the heck was that thing cooling? (IMG:style_emoticons/default/confused24.gif) Well his shop of course (IMG:style_emoticons/default/biggrin.gif) |
Frankvw |
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe ![]() |
the prop had to be buried in the desert since it has 5 liters of DNA on it from the guy that walked into it ? Sell off the rest of the evidence...done !
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,445 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
(IMG:style_emoticons/default/WTF.gif)
It's not even a 914 motor. Just a Type III VW engine. Look at the exhaust port locations. |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
It's not even a 914 motor. Just a Type III VW engine. Look at the exhaust port locations. (IMG:style_emoticons/default/agree.gif) |
poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,139 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
May have been used on an airboat at some point? (IMG:style_emoticons/default/confused24.gif)
Many years ago, I rode in an airboat powered by a VW Type 1 engine. (IMG:style_emoticons/default/driving.gif) |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Yep, that's a type 3 engine including the Solex carbs, so '67 or earlier.
Funny how he has a wire mesh around a 10" fan for the engine cooling and a 4 ft prop wide open... |
73-914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None ![]() ![]() |
Looks like Airboat engine to me also
Nacho |
Member ![]() ![]() Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None ![]() ![]() |
Actually these types of engines are popular for the home builder entry level airplane/gliders.
-Nacho |
ClayPerrine |
Actually these types of engines are popular for the home builder entry level airplane/gliders. -Nacho With the way the prop is attached, I wouldn't even taxi down the runway with that engine. The thrust bearings in a VW motor are not designed with a propeller in mind. Remember, you are pulling all of the thrust created by the propeller against a magnesium engine case. Most home builders use a reduction unit of some kind, both to absorb the thrust load of the propeller and to lower the propeller speed to something that won't have the prop close to supersonic. 3K is about max speed for most fixed pitch propellers. Looking at that picture, I guestimate the prop to have a 30 inch radius. So doing the math, the prop tips are moving at 536 mph at 3000 RPM. AT 5500 RPM (about redline in a VW pushrod engine), the prop tips would be at 767 mph, or Mach 1.2. It definitely needs a reduction drive to use it in an airplane. Clay |
SO.O.C914er |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California ![]() |
It just reeks of crazy (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/chair.gif)
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,440 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Now that's air cooling.
Lo-Fi Version | Time is now: 13th July 2025 - 10:40 AM |
