76 Ign Cylinder lock, Help fixing or replacing |
Tz Toy |
Aug 25 2020, 09:55 AM
Newbie Group: Members Posts: 6 Joined: 15-June 20 From: Seattle'ish WA Member No.: 24,382 Region Association: Pacific Northwest |
Thanks to some great pics here at 914 World, i was able to remove the ign cylinder lock out of my 76, however finding a replacement or place to repair it is proving problematic. My old one will turn as far as "run", but not to "start".
Suggestions? |
ndfrigi |
Aug 25 2020, 10:02 AM
maybe you just need the ignition switch
https://www.pelicanparts.com/cgi-bin/ksearc...gnition+switch# |
dr914@autoatlanta.com |
Aug 25 2020, 10:15 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I agree, the plastic cracks so one cannot reach the crank position any longer
maybe you just need the ignition switch https://www.pelicanparts.com/cgi-bin/ksearc...gnition+switch# |
Bleyseng |
Aug 25 2020, 10:35 AM
I had this problem and it took me a year to figure it out. Installed new ignition switch and same problem,I couldn't get it to fire in the start position. Took it apart and using a screwdriver into the ignition switch it started every time! Finally I noticed the metal tang that comes off the key part was worn down. So I filed it flat and epoxied a new thin piece of metal on it and smoothed it all nice so it fit into the plastic ignition switch part. Starts everytime now.
Tz Toy |
Sep 1 2020, 12:56 PM
Sorry, slow to respond. Had to get garage freed up so I could bring 914 back in. It isn't the ign switch. Starts find with a screwdriver.
In the off position the tang hits the stop, but going towards start, the tang comes up short. |
bdstone914 |
Sep 2 2020, 11:36 AM
@Tz Toy
date='Aug 25 2020, 08:55 AM' post='2845807'] Thanks to some great pics here at 914 World, i was able to remove the ign cylinder lock out of my 76, however finding a replacement or place to repair it is proving problematic. My old one will turn as far as "run", but not to "start". Suggestions? [/quote] I think I may have a spare 76 tumbler assembly. May have a key to it. Or it could be keyed to your key. Rekey cost $40. Lock assembly $50. Bruce |
dangrouche |
Sep 2 2020, 12:44 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
Sorry, slow to respond. Had to get garage freed up so I could bring 914 back in. It isn't the ign switch. Starts find with a screwdriver. In the off position the tang hits the stop, but going towards start, the tang comes up short. Contact "TheCabinetmaker" on this board; he's helpful and he does repairs; you should PM him. |
bdstone914 |
Sep 2 2020, 03:23 PM
@Tz Toy
Edit. I have an assembly I think I may have a spare 76 tumbler assembly. May have a key to it. Or it could be keyed to your key. Rekey cost $40. Lock assembly $50. Bruce [/quote] Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 05:00 PM |
