> Added another Porsche to the collection
dt4
post Aug 25 2020, 01:25 PM
Region Association: England
This was close by and at a price that made it hard to ignore
It is an abandoned project that hasn’t been on the road for about 15 years following a failed clutch change
Needs a lot of mechanical work but the body work and interior is excellent
It’s in storage for now and will be the next project once the 914 is on the roadAttached Image Attached ImageAttached Image
Root_Werks
post Aug 25 2020, 02:09 PM
Village Idiot
I like the 924, had a few ranging from 1978, 79, and I think an 81 and of course an 87"S". Didn't the 924 have a CD of something like .29?
56kabrio
post Aug 25 2020, 08:11 PM
[quote name='Root_Werks' date='Aug 25 2020, 12:09 PM' post='2845860']
Excellence magazine
1979 924 Turbo (924)
engine
TYPEInline 4
INDUCTIONTurbocharged
COOLINGWater-cooled
VALVETRAINSingle overhead camshaft
INJECTIONPort injection
BORE X STROKE3.41 in/86.5 mm x 3.32 in/84.4 mm
DISPLACEMENT121.02 cu-in/1,984 cc
HORSEPOWER150 @ 5500 rpm
TORQUE152 lb-ft @ 3500 rpm
MAX RPM6500
COMPRESSION RATIO7.5:1
transmission
OPTIONS5-speed manual
chassis
TYPEFront-engined, rear-wheel drive
CURB WEIGHT2,822 lbs.
HEIGHT50.00 in/1,270 mm
GROUND CLEARANCE4.92 in/125 mm
LENGTH170.08 in/4,320 mm
WHEELBASE94.49 in/2,400 mm
WIDTH66.42 in/1,687 mm
TRACK FRONT55.83 in/1,418 mm
TRACK REAR54.80 in/1,392 mm
DRAG COEFFICIENT.33
WHEEL SIZE FRONT15 x 6
WHEEL SIZE REAR15 x 6
TIRE SIZE FRONT185/70VR-15
TIRE SIZE REAR185/70VR-15
Still very good for its day.
Mack
dt4
post Aug 26 2020, 12:47 AM
The brakes are seized solid and my Merc had to drag it away from the pit it was over as it wouldn't roll
So everything hub / brake / suspension related on all 4 corners will need to come off.
The transaxle is disconnected but the torque tube is still connected and it was all held up via a transmission jack that was down in the pit. The bell housing at the engine end was disconnected but wasn't drawn back far enough to get to the clutch.
At this point the PO had walked away from the job as he was stuck, he then fell ill and passed away and its been sat ever since.
I pushed the bell housing at the front back over the clutch, put a couple of bolts into hold the torque up and then roped the transaxle to the chassis to take the weight and reconnected the rear drive shafts.
I used the Merc to drag it away from the pit and then got a guy with a trailer and winch to get it over to my Mums place and into her garage for temporary storage
914forme
post Aug 26 2020, 04:24 PM
I love it,I want to see pictures of the Merc...........
You don't know how much I am hoping it is not a Benz but a 50s Mercury Lead Sled with some large Lincoln engine, slammed, and chopped...... (IMG:style_emoticons/default/aktion035.gif)
bkrantz
post Aug 26 2020, 09:13 PM
QUOTE(dt4 @ Aug 26 2020, 12:47 AM) *
Even some brave mechanics have surrendered to the 924/944 clutch job. That was probably the most aggravating repair I ever did.
dt4
post Aug 27 2020, 12:32 AM
QUOTE(914forme @ Aug 26 2020, 11:24 PM) *
sadly not, its a 2005 E class estate / station wagon that can carry a lot of car parts
911GT2
post Aug 27 2020, 01:00 AM
Region Association: Europe
Cool, 924's are fun!
I had a 944S2 once, loved that car. But had to be sold due to moving houses.
Racer
post Aug 27 2020, 05:32 AM
We all know that's not another Porsche, its another NARP! (IMG:style_emoticons/default/wink.gif) Enjoy it!
914_7T3
post Aug 27 2020, 12:19 PM
QUOTE(914forme @ Aug 26 2020, 03:24 PM) *
Great Project and why not add another Porsche to the collection?
Although I was hoping it was a "Black Max" Merc Power (IMG:style_emoticons/default/beer3.gif)
SKL1
post Aug 27 2020, 01:16 PM
Should be an interesting project. Looks like a gray market car with the side blinkers and smaller bumpers...
Had a 944 when they first came out. A great cruiser...
Won't be many at your local C&C...
- Lo-Fi Version Time is now: 7th December 2025 - 07:50 PM
