GB for early fog light spring clips $10.00 a set includes stainless screws, These are live-- made in stainless - |
Mikey914 |
Sep 4 2020, 02:27 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you've lost one of these or it's corroded you know you can't put it back together without this part. There has been some interest in these in the past, but the tooling and cost to make them is a bit steep. I really need to sell 75 sets at $10 a set to get these rolling. I'll make some of the other parts a discounted option to help make an even better deal
Only with the spring clips Add glass in for $20 each clear and $25 amber Seals a set of 2 at $10 a set You can take or leave any of the above, but only available if you do the GB |
bdstone914 |
Sep 4 2020, 06:09 AM
@Mikey914
This is the clip that holds the lens ring to the rear half correct? If so I can use at least five sets Bruce |
bob164 |
Sep 4 2020, 08:28 AM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
I will take 3 sets.
bdstone914 |
Sep 4 2020, 08:44 AM
Note that two of these clips have a square hole. Never figured its purpose. Also note how one is thicker.
bdstone914 |
Sep 4 2020, 08:45 AM
Attached thumbnail(s) |
Mikey914 |
Sep 4 2020, 11:24 AM
@Mikey914 This is the clip that holds the lens ring to the rear half correct? If so I can use at least five sets Bruce Yes it is |
76-914 |
Sep 5 2020, 09:55 AM
You might want to consider supplying the small machine screw as well. (IMG:style_emoticons/default/beerchug.gif)
IronHillRestorations |
Sep 5 2020, 10:24 AM
Life is funny! I spent about 30 mins fabricating one of those last night for a customer's car. $10 for a pair is a deal!! (IMG:style_emoticons/default/first.gif)
Sep 5 2020, 01:41 PM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes please
porbmw |
Sep 5 2020, 09:40 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Hi Mark
I'll take 2 sets Thx Paul |
jim_hoyland |
Sep 8 2020, 06:02 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
One set of the clips, and one set of seals; do I need to order from the 924 Rubber site ?
Mikey914 |
Sep 8 2020, 08:04 PM
Not yet, Trying to drum up enough interest to do these. I think there will be but I need to spread the tooling cost over quite a few pieces to make this work.
If you sign up here I'll let you know when they are ready. |
bdstone914 |
Sep 14 2020, 02:51 PM
@Mikey914
' date='Sep 8 2020, 07:04 PM' post='2849621'] Not yet, Trying to drum up enough interest to do these. I think there will be but I need to spread the tooling cost over quite a few pieces to make this work. If you sign up here I'll let you know when they are ready. [/quote] I will take ten sets if that helps. And some lenses and rubber seals. Can I get some seals now to get started on assembling the lights ? Bruce |
bdstone914 |
Sep 15 2020, 11:31 AM
@76-914
@mikey914 date='Sep 5 2020, 08:55 AM' post='2848701'] You might want to consider supplying the small machine screw as well. (IMG:style_emoticons/default/beerchug.gif) [/quote] Better to do a complete rebuild kit with 4mm screw, lock washer, kit lens gaskets, bottom clip, internal clips, rear grommet, new wires. A complete rebuild kit. I have to replace all those parts when I restore sets. |
76-914 |
Sep 15 2020, 02:42 PM
[quote name='bdstone914' date='Sep 15 2020, 10:31 AM' post='2851552']
@76-914 @mikey914 date='Sep 5 2020, 08:55 AM' post='2848701'] You might want to consider supplying the small machine screw as well. (IMG:style_emoticons/default/beerchug.gif) [/quote] Better to do a complete rebuild kit with 4mm screw, lock washer, kit lens gaskets, bottom clip, internal clips, rear grommet, new wires. A complete rebuild kit. I have to replace all those parts when I restore sets. [/quote] Makes sense. (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
Sep 15 2020, 05:43 PM
[quote name='76-914' date='Sep 15 2020, 01:42 PM' post='2851594']
[quote name='bdstone914' date='Sep 15 2020, 10:31 AM' post='2851552'] @76-914 @mikey914 date='Sep 5 2020, 08:55 AM' post='2848701'] You might want to consider supplying the small machine screw as well. (IMG:style_emoticons/default/beerchug.gif) [/quote] Better to do a complete rebuild kit with 4mm screw, lock washer, kit lens gaskets, bottom clip, internal clips, rear grommet, new wires. A complete rebuild kit. I have to replace all those parts when I restore sets. [/quote] Makes sense. (IMG:style_emoticons/default/beerchug.gif) [/quote] Planned to I even make the spring clips and can add options for new glass. SO yes complete kits will be available, but you can just buy the springs if you want. (IMG:style_emoticons/default/biggrin.gif) |
maf914 |
Sep 17 2020, 06:30 AM
I am in for the spring clips. I have a pair of fog lights in need of a rebuild. Thanks, Mark.
Rusty |
Sep 17 2020, 04:59 PM
I'm in on a set.
mb911 |
Sep 18 2020, 07:06 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Yes
71914-4 |
Sep 19 2020, 09:54 AM
Newbie Group: Members Posts: 21 Joined: 2-October 15 From: Central Texas Member No.: 19,226 Region Association: None |
A complete set please.
Lo-Fi Version | Time is now: 18th May 2024 - 07:19 PM |
