Any D Jet experts in Seattle? |
Robson51 |
Sep 5 2020, 12:00 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Looking for some help from an in person human being before going to Webers.
Anyone out in Seattle (actually just north) that wants to make some side money? TIA |
Bleyseng |
Sep 5 2020, 05:26 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
First- Is the Cylinder Temp sensor good? Test it per PB Anders site. So carefully remove it without losing the little washer. What the number? Ending in 003- 012 or 017? What ECU do you have?
Test the CHT cold (ohms resistance) and then in boiling water. That sensor controls the AFR depending on the engine temperature and usually if its hard to start and rich thats the problem. Or it mis matches with the ECU casing problems. MPS is good. How did you test it? With a vacuum pump pulling 15hg and no leakdown after 5 minutes?? |
Robson51 |
Sep 5 2020, 05:57 PM
First- Is the Cylinder Temp sensor good? Test it per PB Anders site. So carefully remove it without losing the little washer. What the number? Ending in 003- 012 or 017? What ECU do you have? Test the CHT cold (ohms resistance) and then in boiling water. That sensor controls the AFR depending on the engine temperature and usually if its hard to start and rich thats the problem. Or it mis matches with the ECU casing problems. MPS is good. How did you test it? With a vacuum pump pulling 15hg and no leakdown after 5 minutes?? CHT is new, but will check the number. I've only seen one listed for sale for '74 2.0 Will check the number on the ECU. Yes, MPS passed a leakdown test. |
Lo-Fi Version | Time is now: 8th May 2024 - 02:22 AM |
