Any D Jet experts in Seattle? |
Robson51 |
Sep 5 2020, 12:00 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Looking for some help from an in person human being before going to Webers.
Anyone out in Seattle (actually just north) that wants to make some side money? TIA |
Bleyseng |
Sep 5 2020, 07:12 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
"ECU is 11 clicks from full stop left"
Do you mean it is turned CW or CCW? There should be a small notch at the idle mix knob so I would set it there. That is the Factory setting I am not sure how you have it set. |
Robson51 |
Sep 6 2020, 09:07 AM
"ECU is 11 clicks from full stop left" Do you mean it is turned CW or CCW? There should be a small notch at the idle mix knob so I would set it there. That is the Factory setting I am not sure how you have it set. I heard from Continental Motors to turn it all the way CCW then back to the right CW 11 clicks. It’s back to the factory setting. |
Bleyseng |
Sep 6 2020, 04:53 PM
"ECU is 11 clicks from full stop left" Do you mean it is turned CW or CCW? There should be a small notch at the idle mix knob so I would set it there. That is the Factory setting I am not sure how you have it set. I heard from Continental Motors to turn it all the way CCW then back to the right CW 11 clicks. It’s back to the factory setting. No, there is a tiny notch in the lip and that is the Factory setting. But the way to set the idle mix is to run the car until its hot say, 20 minutes of driving. Plug the AAR hoses to make sure no leaks and then adjust the idle screw on the ECU slowly till it runs the best. Wait 30 secs at each click for the engine to adjust to the new mixture setting. 11 clicks CW sounds really rich to me. I'll take a pic of the notch. |
Robson51 |
Sep 8 2020, 02:31 PM
"ECU is 11 clicks from full stop left" Do you mean it is turned CW or CCW? There should be a small notch at the idle mix knob so I would set it there. That is the Factory setting I am not sure how you have it set. I heard from Continental Motors to turn it all the way CCW then back to the right CW 11 clicks. It’s back to the factory setting. No, there is a tiny notch in the lip and that is the Factory setting. But the way to set the idle mix is to run the car until its hot say, 20 minutes of driving. Plug the AAR hoses to make sure no leaks and then adjust the idle screw on the ECU slowly till it runs the best. Wait 30 secs at each click for the engine to adjust to the new mixture setting. 11 clicks CW sounds really rich to me. I'll take a pic of the notch. Did you ever get around to taking a picture of your ECU and the notch? Thanks- |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:18 AM |
