Any D Jet experts in Seattle? |
Robson51 |
Sep 5 2020, 12:00 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Looking for some help from an in person human being before going to Webers.
Anyone out in Seattle (actually just north) that wants to make some side money? TIA |
Bleyseng |
Sep 5 2020, 06:46 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
MPS number is 043? ECU number is ending in 044?
So one plug is wet so I would test it by pulling it and putting in a glass see thru bottle. Disconnect the coil wires so there is no spark and with a assistant or remote start button look at the spray pattern and if it leaks. Heck check them all then you know they are good. Disconnect the cold start valve and bypass the fuel hose to it to get it out of the fuel system as here its really not needed. |
Robson51 |
Sep 7 2020, 12:18 PM
MPS number is 043? ECU number is ending in 044? So one plug is wet so I would test it by pulling it and putting in a glass see thru bottle. Disconnect the coil wires so there is no spark and with a assistant or remote start button look at the spray pattern and if it leaks. Heck check them all then you know they are good. Disconnect the cold start valve and bypass the fuel hose to it to get it out of the fuel system as here its really not needed. Plugged the cold start and still super rich. Runs with black smoke and won’t idle. MPS ends in 043. ECU ends in 044. CHT is a new one from 914Rubber says conforms to 0 280 130 012 spec. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:01 PM |
