Interest in 5 lug cheap wheel? |
mb911 |
Sep 9 2020, 09:21 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am looking at possibly have 7,8,9x15 wheels made for an inexpensive option to what is out there. The manufacturer makes wheels for all the major racing circuits that use steel wheels. Thinking of a powdercoat old school silver with no red stripe. Target would be less then $400 for a set of 4. Would there be interest in them? Yea I would do a group buy to get it rolling.
What does everyone think? |
MM1 |
Sep 9 2020, 09:26 AM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
4 and 5 lug?
Same 6-slot "flat D" design? 15",16", 17", ? |
VaccaRabite |
Sep 9 2020, 09:27 AM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
That's pretty awesome!
Any idea of weight and ET? I have a set of cookies when I finally go 5 Lug, but I like the look of these in black. Pending a little more information I'd be tentatively interested. Rod had a set similar (4 bolt though) on his black car, and they look badassed. Zach |
mb911 |
Sep 9 2020, 09:49 AM
I would have them made in 5 lug only at 1st and run the standard 911 offset which I believe to be 23mm.. This is all thinking outloud at the moment but it 100% doable for that price point.. Thinking the D hole would be the standard.
PanelBilly |
Sep 9 2020, 11:22 AM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I’m interested.
Gary |
Sep 10 2020, 02:53 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
I would have them made in 5 lug only at 1st and run the standard 911 offset which I believe to be 23mm.. This is all thinking outloud at the moment but it 100% doable for that price point.. Thinking the D hole would be the standard. Ben, 23mm is the offset of the 911 7 inch wheels; 6's are 36mm; 8's are 10.6mm (951 P/N are 23mm). Nice chart here: Wheel offsets from Pelican. |
andrewck |
Sep 10 2020, 03:38 PM
Newbie Group: Members Posts: 48 Joined: 5-July 20 From: Denver Member No.: 24,461 Region Association: Rocky Mountains |
Good idea and interested. Is there really that much more interest in having a 9" vs. a 6, 7, 8?
Mark Henry |
Sep 10 2020, 04:07 PM
Any idea of weight and ET? I have a set of cookies when I finally go 5 Lug, but I like the look of these in black. Pending a little more information I'd be tentatively interested. I'm guessing around or over 20 lbs, my EMPI Sprint stars 6" steel wheels were/are much heavier than 4 bolt fuchs. I could weigh one of each if you like. |
mb911 |
Sep 10 2020, 04:14 PM
Weight is about 16lbs each.
Gary yes I would have them built to the ET listed you referenced |
ValcoOscar |
Sep 10 2020, 04:27 PM
Garage Life Group: Members Posts: 2,384 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
Weight is about 16lbs each. Gary yes I would have them built to the ET listed you referenced ____________________________ (IMG:style_emoticons/default/idea.gif) 16 Lbs is not bad. (IMG:style_emoticons/default/popcorn[1].gif) Oscar |
RickS |
Sep 10 2020, 09:43 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
They would good painted flat gold.
Andyrew |
Sep 11 2020, 12:12 AM
Make em 17's and 9 and 10" wide with proper offset... Like zero options out there for that less than $4k....
There are a ton of 15" wheel options out there, No real tire options.. Same goes for 16" Its one of the big reasons why guys that race run 17"+ Because its that, or your stuck with hoosiers. I know you guys hate big wheels, but 16" tire options have dried up, as have 15" for street/sticky rubber without it being the miata size. |
808 WRX |
Sep 11 2020, 12:18 AM
Member Group: Members Posts: 58 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California |
Would a 15x7" wheel with a 23 mm offset fit on a narrow body car without rolling the fenders? And how wide of a tire could I get away with?
914 Ranch |
Sep 11 2020, 05:12 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,411 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
205.
Lo-Fi Version | Time is now: 14th May 2024 - 09:32 PM |
