NLA part request - 421 839 455, Anyone have one stashed away? |
IronHillRestorations |
Sep 11 2020, 05:37 AM
I. I. R. C. Group: Members Posts: 6,720 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Looking for the gummi O ring for the front grease cap on 4 cyl, it's NLA
Factory part number is 421 839 455 I'm trying to get 914Rubber to reproduce this part, would you buy some if available? Attached image(s) |
bdstone914 |
Sep 11 2020, 08:20 AM
bdstone914 Group: Members Posts: 4,525 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@IronHillRestorations
I never knew one was there. Have you searched for a common o-ring replacement? |
Bleyseng |
Sep 11 2020, 11:50 AM
That O ring looks like its for the 914/6 front grease cap not a 4 cyl model.
914Sixer |
Sep 11 2020, 12:57 PM
914 Guru Group: Members Posts: 8,889 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All VW products had one in the 1970s, most were never replaced when removed.
Sep 11 2020, 01:07 PM
914-6 GT in waiting Group: Members Posts: 19,284 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
All VW products had one in the 1970s, most were never replaced when removed. (IMG:style_emoticons/default/agree.gif) often overlooked. But it's a pretty generic use. Something "in the ballpark" should be fine. |
Sep 11 2020, 01:40 PM
barefoot |
Sep 11 2020, 01:53 PM
Senior Member Group: Members Posts: 1,276 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Mc Master Carr carries all kinds of O-Rings, should be able to find one close enough
Nacho |
Sep 11 2020, 01:57 PM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
Mc Master Carr carries all kinds of O-Rings, should be able to find one close enough (IMG:style_emoticons/default/agree.gif) |
Mikey914 |
Sep 11 2020, 02:25 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Its not a standard rubber o ring. Thats qhy im looking at doibg these.
rgalla9146 |
Sep 11 2020, 06:10 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
It iwas never on a 6 or a 911 It is not a standard type O ring, it's soft , foam-like. As seen in the photo it has a glued seam, made from running material. |
Mikey914 |
Sep 11 2020, 06:55 PM
We can make a as a unglued piece or same way pretty inexpensively.
bdstone914 |
Sep 11 2020, 09:51 PM
Mc Master Carr carries all kinds of O-Rings, should be able to find one close enough (IMG:style_emoticons/default/agree.gif) I found this flat one that looks like it will work. Attached thumbnail(s) |
Mikey914 |
Sep 12 2020, 03:15 AM
Actually looking for an original. We plan to replicate or improve the design. Oil based greases will attack rubber. Viton is most likely the best option.
GeorgeKopf |
Mar 12 2022, 02:31 PM
Member Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
Any movement on this? My hub seals fell apart when I pulled off the hubs.
I'm thinking that part number: 2418T199 on McMaster-Car, might be perfect. Soft Rubber Oil Resistant 48mm = 1 7/8 inner diameter 3/16" thick Round profile Thanks. George |
Lo-Fi Version | Time is now: 24th May 2024 - 01:00 AM |
