IronHillRestorations
Sep 11 2020, 05:37 AM
Looking for the gummi O ring for the front grease cap on 4 cyl, it's NLA
Factory part number is 421 839 455
I'm trying to get 914Rubber to reproduce this part, would you buy some if available?
bdstone914
Sep 11 2020, 08:20 AM
@IronHillRestorations I never knew one was there. Have you searched for a common o-ring replacement?
Bleyseng
Sep 11 2020, 11:50 AM
That O ring looks like its for the 914/6 front grease cap not a 4 cyl model.
914Sixer
Sep 11 2020, 12:57 PM
All VW products had one in the 1970s, most were never replaced when removed.
Sep 11 2020, 01:07 PM
QUOTE(914Sixer @ Sep 11 2020, 02:57 PM)
often overlooked. But it's a pretty generic use. Something "in the ballpark" should be fine.
Sep 11 2020, 01:40 PM
QUOTE(Bleyseng @ Sep 11 2020, 09:50 AM)
Don't think the 5 lug cars had one.
They were available a few years ago.
barefoot
Sep 11 2020, 01:53 PM
Mc Master Carr carries all kinds of O-Rings, should be able to find one close enough
Nacho
Sep 11 2020, 01:57 PM
QUOTE(barefoot @ Sep 11 2020, 02:53 PM)
Mikey914
Sep 11 2020, 02:25 PM
Its not a standard rubber o ring. Thats qhy im looking at doibg these.
rgalla9146
Sep 11 2020, 06:10 PM
It iwas never on a 6 or a 911
It is not a standard type O ring, it's soft , foam-like.
As seen in the photo it has a glued seam, made from running material.
Mikey914
Sep 11 2020, 06:55 PM
We can make a as a unglued piece or same way pretty inexpensively.
bdstone914
Sep 11 2020, 09:51 PM
QUOTE(Nacho @ Sep 11 2020, 12:57 PM)
I found this flat one that looks like it will work.
Mikey914
Sep 12 2020, 03:15 AM
Actually looking for an original. We plan to replicate or improve the design. Oil based greases will attack rubber. Viton is most likely the best option.
GeorgeKopf
Mar 12 2022, 02:31 PM
Any movement on this? My hub seals fell apart when I pulled off the hubs.
I'm thinking that part number: 2418T199 on McMaster-Car, might be perfect.
Soft Rubber
Oil Resistant
48mm = 1 7/8 inner diameter
3/16" thick
Round profile
Thanks.
George
