Fuel pump, What have y’all used lately |
Porschef |
Sep 13 2020, 03:08 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Chasing an intermittent hesitation/cutting out issue; it’s not constant (which is an obvious drawback); I took the car out this morning for a good 50 mile ride. The nonsense started a couple miles from home, but I kept going as it seems to subside after a while. Took almost half the trip before it stopped being a problem, after that it ran like a bull.
I’m thinking the 40+ year old fuel pump may be telling me it’s getting tired, so I’d like to replace it with a new one. So I’m looking to find out what seems to be a solid replacement, Bosch, Airtex, or whatever. Any input greatly appreciated. TIA, Joe |
BeatNavy |
Sep 13 2020, 03:15 PM
Hey Joe!
I converted to the Bosch 2 port a couple of years ago (IIRC, part number is 69133). No issues whatsoever, and the fuel hose routing is a bit simpler as you don't need the return line. Good luck (IMG:style_emoticons/default/beerchug.gif) |
rmital |
Sep 13 2020, 03:25 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
Hey Joe! I converted to the Bosch 2 port a couple of years ago (IIRC, part number is 69133). No issues whatsoever, and the fuel hose routing is a bit simpler as you don't need the return line. Good luck (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) but you already knew that.... (IMG:style_emoticons/default/beerchug.gif) |
rmital |
Sep 13 2020, 04:29 PM
Hey Joe! I converted to the Bosch 2 port a couple of years ago (IIRC, part number is 69133). No issues whatsoever, and the fuel hose routing is a bit simpler as you don't need the return line. Good luck (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) but you already knew that.... (IMG:style_emoticons/default/beerchug.gif) and....be sure to invest in Chris Foley's fuel pump mount. this fabricated piece of art is perfect for the job. |
mlindner |
Sep 13 2020, 04:53 PM
Senior Member Group: Members Posts: 1,526 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
ClayPerrine |
Sep 13 2020, 06:20 PM
Life's been good to me so far..... Group: Admin Posts: 15,504 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Airtex E-8445 or equivalent. Same pressure and volume as the stock pumps. Available at your FLAPS.
I have run one for years with no issues. Clay |
Frankvw |
Sep 14 2020, 07:15 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
I used the Bosch 69133
You can see it in my topic 'from 3 to 2 port pump' http://www.914world.com/bbs2/index.php?showtopic=345333 Good luck with the conversion ! |
Porschef |
Sep 14 2020, 07:38 AM
Thanks for the replies, the pump is in the front.
I’ll look at the Airtex, thanks |
Olympic 914 |
Sep 14 2020, 07:48 AM
Group: Members Posts: 1,673 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Used the Bosch 044. inline. Comes with a check valve but I didn't use it.
Supposed to be good to 70+ lbs pressure. Only downside is its noisy. Can't here it much over the engine. But you can definitely hear it power on when you turn the key. |
Olympic 914 |
Sep 14 2020, 07:54 AM
If you need a mount, I have this one you can have for shipping.
Porschef |
Sep 14 2020, 01:19 PM
Thanks Tom, that’s very generous, however I’m probably gonna go with a direct replacement; hopefully they’re the same size. (IMG:style_emoticons/default/beerchug.gif)
saigon71 |
Sep 14 2020, 06:52 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Airtex E-8445 or equivalent. Same pressure and volume as the stock pumps. Available at your FLAPS. I have run one for years with no issues. Clay (IMG:style_emoticons/default/agree.gif) |
Highland |
Sep 14 2020, 10:34 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Does anyone know from experience if the Airtex is quiter than the Bosch.
rmital |
Sep 15 2020, 05:52 AM
ClayPerrine |
Sep 15 2020, 12:36 PM
The Airtex pump is only noisy if it gets against something. Using the mounts that come with it, it is almost silent.
Lo-Fi Version | Time is now: 4th June 2024 - 09:33 AM |
